Easy question but I get a crazy answer
  • Thread starter Thread starter sai2020
The problem involves estimating the inner diameter of a thermometer tube based on the thermal expansion of mercury. The original poster attempts to apply the thermal expansion coefficient to calculate the change in volume and subsequently the radius of the tube.
  • Participants discuss the calculation of volume for a cylinder and question the assumptions made regarding initial volume and the expansion of the glass container. There are attempts to clarify the derivation of certain equations and the implications of unit conversions.
The discussion is ongoing, with participants providing tips and questioning the assumptions made in the calculations. Some guidance has been offered regarding the need for initial volume and the relevance of the glass expansion, but no consensus has been reached on a definitive approach.
There is mention of missing information, such as the initial volume, and uncertainty about whether the expansion of the glass should be considered. The original poster acknowledges potential errors in their calculations.
sai2020
The question is
Mercury has a thermal expansion coefficient (volume) of about 1/5500 perKelvin. Estimate the inner diameter of the thermometer tube.
Here's my attempt.
L [tex]\approx[/tex] 30cm
V = 2*pi*r^2*L
Change in volume at 0 C and 110 C approximately equal to V
=> 110/5500 = r^2(3*pi/5)
=> r = sqrt(1/30*pi) [tex]\approx[/tex] 0.10m
I am well known to make crazy errors but I can't find out where that is over here
there's not enough information to determine an actual value for the diameter. You give no initial volume (Vo) and I don't know if you need to consider the expanding glass container as well. Given the assumptions that the volume at 0 C is unknown and the expansion of glass is negligible, I got a solution of
d = 0.2899*sqrt(Vo)
Just a few tips to help you on your way;
Recheck how you determine the volume of a cylinder.
Where does (3*pi/5) come from?
What are your justifications for those assumptions in the problem? There's insufficient data to complete it with the question you provided.
Make sure you don't fluke up on units.
Remember that 100 cm^2 =/= 1 m^2. 100^2 cm^2 = 1 m^2
Another clue: the point of a decent thermometer is to provide sufficient changes in length to read (say) a quarter-degree change in temperature.
It comes from
L = 30*10^-2 = 0.3m
V = r^2(2*pi*L) = r^2(3*pi/5)
d = 0.2899*sqrt(Vo)
The *Hint* says the initial volume is 1mm^3. and I think the glass expansion can be neglected cos this is an introductory thermal course and this is the first tutorial.
Can you please tell me how you got to that.
*I made a mistake in my first post, that should be the radius, r not the diameter, d
I just used the equation
dV = B*dT*Vo
where:
dV = change in volume (0.03 x pi x r^2)
B = expansion coefficient (18x10^-5/C)
dT = change in temp (110C)
Vo = initial volume (1mm^3)
Plug all that in and solve for r and you get r = 0.2899*sqrt(Vo).
OH! My definition of B was wrong.. Thanks a lot..
21K
12K
