Is antimatter a theory or does it exist?
  • Context: Undergrad
  • Thread starter Thread starter azzkika
    Antimatter Theory
The discussion centers around the existence of antimatter, questioning whether it is merely a theoretical concept or a physical reality. Participants explore its properties, interactions with matter, and implications for the laws of physics, touching on both theoretical and experimental aspects.
  • Some participants assert that antimatter is not just a theory, citing experimental evidence from particle collisions at facilities like the Tevatron and the use of positron emission tomography (PET) in medical imaging.
  • Others define antimatter as particles with opposite charges to their matter counterparts, such as positrons and anti-protons, and discuss the implications of these definitions.
  • A viewpoint suggests that matter and antimatter are made of the same fundamental components but differ in charge configuration, allowing for interactions without significant force.
  • Some participants express skepticism about the concept of antimatter, questioning the nature of mass and energy conservation in the universe, and whether antimatter implies negative mass.
  • There are discussions about the annihilation of matter and antimatter upon contact, with some participants clarifying that this is why antimatter is rare in the universe.
  • Several participants debate the mass of photons, with conflicting claims about whether they are massless or possess an unobservably small mass.
  • Some participants highlight that charge is not the only distinguishing factor between matter and antimatter, noting that neutrons and anti-neutrons are both uncharged yet distinct.
  • There are references to the theoretical implications of quantum numbers and particle composition in defining antimatter.
Participants do not reach a consensus on the nature of antimatter, with multiple competing views and ongoing debates about its properties, existence, and implications for physics.
Some claims about the mass of photons and the nature of antimatter interactions remain unresolved, with participants expressing differing beliefs and interpretations without definitive experimental evidence to support all assertions.
azzkika
Is antimatter a theory or does it exist??
Does antimatter really exist?? if so, what is it made of, if not matter?? and is it subject to the same laws as normal matter?? i personally can't see how it is possible. in another thread i read that in a void where there is nothing it is possible for matter to emerge from nothing as long as an equal amount of antimatter emerges.
i know this is a theory, but has it ever been observed??
i personally think the mass and energy of the universe is unchangeable, but as ever there are differing opinions on this. for it to be unchangeable the antimatter theory must be incorrect as antimatter if it did exist could be composed of antimass, as anything that exists requires mass no matter how small. even light has mass, just a very very very small mass per photon.
Er... antimatter a "theory"? What do you think they have been colliding at the Tevatron all these years? Or even at LEP before it went away? And guess what the "P" in PET scan means that is now used in many medical procedure?
Zz.
I like your thinking. Matter and antimatter are made of the same stuff. It's just that they are in different configurations. Giving antimatter the opposite charge of what we consider to be matter.
Its this charge difference that allows matter/antimatter collisions to occur with little to no need for force(like trying to fuse protons).
Of course it does. You are mistakenly thinking that antimatter means negative mass. An anti-electron (aka a positron, the P in PET) has the same mass but exactly the opposite charge as an electron. The same goes for anti-protons: same mass but opposite charge as a proton.
You are entitled to your own opinions, but not your own facts. The fact is that mass and energy are interchangeable. The US used this fact to its advantage to end World War II against Japan. Were this fact not true, the Sun couldn't shine. The photons in the sunlight are mass converted to energy in the center of the Sun by means of nuclear fusion.
No, it doesn't. Photons are massless.
One point that has not been made. Charge is not the only factor in matter antimatter difference. Neutrons have anti-neutrons, although both are uncharged.
I did leave out neutrals, which also have their anti-matter partners.
Perhaps this will help - http://www2.slac.stanford.edu/vvc/theory/hadrons.html
The baryons have (qqq), where q is a quark (u, d, s), while their anti-particles are ([itex]\bar{q}\bar{q}\bar{q}[/itex]).
http://www2.slac.stanford.edu/vvc/theory/antiquarks.html
The term matter is then extended, by convention, to include:
  • All quarks, (charges +2/3 and -1/3).
  • All negatively charged leptons.
  • Left handed neutrinos.
Antimatter is, then, any particle built from:
  • Antiquarks (charges of -2/3 or +1/3).
  • Positively charged leptons.
  • Right-handed neutrinos.
Photons as defined by QED. Otherwise, you can not rule out an unobservably small photon mass. This is actually very convenient, because you can make your calculations with a tiny photon mass, forgetting about gauge invariance, and set the photon mass to zero at the end of the day will not spoil your result.
Exchange all quantum numbers in general should do the trick. Electric charge, color charge, weak charge, helicity...
That's not a good example, because neutrons are composed of quarks, which are individually charged, with the total charge being zero. An antineutron is composed of the corresponding antiquarks, which each have the opposite charge to their respective quarks, with the total still being zero.
A better example would be the neutrinos, which are fundamental particles as far as we know, and which have antiparticles.
i asked the question because i read somewhere that anti matter explodes upon coming into contact with normal matter therefore we don't have any. obviously i am wrong. thanks for informing me. lol
and i cannot believe photons are massless as they exist. i believe they are just so light as to be almost unmeasurable and when coming into contact with other mass an equal weight is dispersed by reflection / refraction etc. hence all things don't lose or gain mass from light.this is only as i can't believe a thing can have zero mass and exist, (apart from a void or a vacuum i suppose).
If you are wrong then so is the Star Trek propulsion system. hehehe
Luckily, physics is typically verified not simply based on beliefs, but experiment. Till you can show an experimental evidence that photons have a non-zero, detectable mass, then your belief has no foundation.
And a photon isn't a "thing", the same way "kinetic energy" isn't a thing.
Zz.
When I Google 'is a photon a thing' , I get sent right back to here. https://www.physicsforums.com/showthread.php?p=1749537
Lightarrow says: (post #45)
"The subatomic particle that carries the electromagnetic force and is the quantum of electromagnetic radiation. The photon has a rest mass of zero, but has measurable momentum, exhibits deflection by a gravitational field, and can exert a force. It has no electric charge, has an indefinitely long lifetime, and is its own antiparticle."
Sounds like a 'thing' to me. If not, in gravitational lensing, What is getting lensed?
Antimatter and matter do annihilate one another upon coming into contact, and that is exactly why we don't have (much) antimatter around us. That is also exactly how positron emission tomography works. Carbon-11, nitrogen-13, oxygen-15, and fluorine-18 decay via positron emission into other kinds of nuclei. For example, carbon-11 decays into boron-11 with a half-life of about 20 minutes. The positrons emitted from the decay don't live very long. As soon as they meet up with electrons the positrons and electrons annihilate one another. The PET scanner detects the gamma rays that result from this annihilation.
Statements like this give me that same, terrible feeling as you get when you scratch your nails against a chalkboard! It's not azzkika's fault, or anyone's fault I suppose, but it's sad that this kind of logic pushes into the public forum, and leads people to spectacularly false conclusions.
The problem, azzkika, is scale! If you take an electron and a positron (antielectron) and throw them together (slowly so kinetic energy is irrelevant), then out would come two photons, with a total energy of 500 keV (500,000 electron-volts). 1 eV is about [itex]10^{-19}[/itex] Joules, where 1 Joule is (roughly) the energy of a 1kg weight moving at 1 m/s. As you can see, this hardly qualifies as an "explosion!"
However, let's say you're not talking about a SINGLE electron or positron, but let's say you have a CHUNK of matter and antimatter, like a gram or more. There are something like $10^{27}$ electrons in a gram, so when you multiply it out, it suddenly becomes quite a LARGE explosion!
But you see, there are no antimatter chunks around here! So this kinda thing just doesn't happen. And it would be near impossible to make a chunk of antimatter that large, just because it wouldn't be stable in our matter-dominated universe! That is, it would fall apart before it ever got that big.
Antimatter explosions are PURE science fiction!
This issue of scale is very important in physics! This same kind of logic leads people to protest outside our national labs because we're going to make "black holes that will swallow up the universe!" Er...
NO!
Thank you blechman.
I know your reply was to azzkika, but I want to thank you for the answer anyway.
Clear and understandable to people like me with far more curiosity than knowledge.
I grew up on Sci-Fi and have seen so many of the 'impossible' things become reality that it blurs the distinction between what is, and what can or cannot be.
Even during the emergence of the 'big bang' ? I was sort of under the impression that such energy was in part an explanation for the expansion phase ( inflation ? ) and the subsequent universe we have today.
Or is that just more Science fiction?
That statement sounds simple and correct also.
( don't go into detail please. I don't want to hijack the thread topic. ) Just curious.
The issue is what you mean exactly by 'impossible'! I would claim that creating a macroscopic nugget of antimatter is quite impossible by today's standards, strictly from an engineering standpoint, and that it's certainly not what's happening at particle detectors (which I know is not what you suggest, but I just want to clear that up).
without going into details at all (there are a few issues with this statement you made, but I don't want to get into that here): I should have been more careful and say that such things are impossible TODAY (when the universe has cooled off considerably since the inflation epoch.
Referring to azzkika's statement: I take issue with the colloquial use of the word explosion - one thinks of an atom bomb going off! Not the case in any practical sense. People hear the word "matter" and "antimatter" in the same sentence and they think: "OH G-D, the universe is going to explode!" This is the myth I was trying to debunk. Just because one matter particle meets one antimatter particle in a bar, doesn't mean the big bang is going to repeat itself!
details avoided as much as possible.
I'm sorry to sound so jaded (I'm trying very hard not to sound offensive), it's just that it is very important to keep this notion of size and scale in mind when talking about these things - I have had sooo many people come to me asking about super-explosions at Fermilab since there is "matter-antimatter collisions" there, it's just hard not to have my blood pressure go up! It's not that it's anyone's fault, it's just that the general public isn't correctly informed about what's really going on. I hope this little rant, as silly as it might be, helps people to see my point.
ADDED: I also don't mean to "hijack the thread" - I"m sorry if that's what I ended up doing.
Consider me as one of the 'general public' and again, I thank you for helping us update our views.
I understand your point. Please don't implode our planet. hehehe Arrrrrgggg ! Ya I see the frustration.
Keep the blood pressure in check, and persevere. We need you.
It depends on what you mean by a "thing". Would the OP consider this as a thing as well? After all, he/she found it difficult for a "thing" to have no mass. Do you also consider "kinetic energy" to be a thing? After all, it has "energy", can do work, and in many cases, can be measured. Is this consistent with what you call a "thing" like the pen on your desk?
Zz.
No, Because the statement is not complete to me. The kinetic energy... of this thing, is the complete statement.
If we can detect a single (thing) proton. It becomes a thing to me with all the attributes of a thing for that reason. One of the attributes to the thing may be Kinetic energy, but the attribute is not the thing in itself.
Does kinetic energy get lensed in a gravity field?
I thought the fact that gravity is the attraction of matter to matter and the fact light is affected by gravity indicates mass for attraction to take effect.
Sorry if I offended anybody,
If I'm not banned I'd like to thank Joel for the great talk he gave at Black Pine school here in Berkeley.
Anti Hydrogen is his specialty. Anti Protons are only available at Cern and only in season so look for more great work on this as it comes in.
Two and a half years ago...
and counting. Some things never change. Recent article in Nature is a paper by the author.
See
ALPHA at Cern
But how does that make sence? If you have a group of identical atoms and then a group of antimatter that has an equaly negative mass then should't they disable each other instead of exploding?
I could be wrong about this but I don't think negative mass is allowed. In any case the Charge, parity and time constraints ought to be satisfied. Your question seems to be whether there will be energy released in an anihilation event. Without answering I say that is a good question. Further,if energy is released and matter disappeared, then is it all electromagnetic, part kinetic with a little gravity thrown in or what?
Antimatter doesn't have a negative mass. They have the same mass as their corrosponding particles. They have an opposite charge though.
Yes, you have to invert all matter quantum numbers to change from a particle to its anti-particle. In addition to the already mentioned electric charge, there are things like lepton number and baryon number.
So anti matter isn't really anti matter at all. It is matter with opposite charge. Still matter in my view. I wish science would not have such ambiguous misleading terms such as this.
  • · Replies 21 ·
  • · Replies 24 ·
  • · Replies 30 ·
  • · Replies 18 ·
