Velocity & Volume Change in Ideal Fluids
In the context of ideal fluids, when the pipe length is doubled and the radius is decreased by a factor of 2, the volumetric flow rate remains constant while the velocity increases by a factor of 4. This conclusion is derived from the equation Q = Av, where A represents the cross-sectional area of the pipe. In real fluids, the velocity increase would be less pronounced due to factors such as friction and pressure differences, but the assumptions of incompressibility and constant volumetric flow rate are crucial for this analysis.
  • Understanding of fluid dynamics principles
  • Familiarity with the equation of continuity (Q = Av)
  • Knowledge of ideal vs. real fluid behavior
  • Basic concepts of pressure differences in fluid flow
  • Study the implications of the Bernoulli equation in fluid dynamics
  • Explore the differences between ideal and real fluid flow
  • Learn about the effects of friction in pipe flow
  • Investigate the concept of incompressible fluids in various applications
Students and professionals in engineering, particularly those focusing on fluid mechanics, as well as anyone interested in the behavior of fluids in varying conditions.
Gear2d
In an ideal fluid, the pipe length is doubled, while radius is decreased by factor 2 what will have to the velocity and volume that is flowing?
Q=Av = pi*r^2*v
From this the volume that will pass, in ideal fluid cases, is constant (same throughout), but the velocity will increase by a factor of 4 since: Q/v = pi*r^2. Is this correct?
Also if I were considering the radius decreasing by a factor of 2, in real fluids, the velocity would increase by it would not increase as much as seen in ideal fluids?
Makes sense to me. Assuming the fluid is incompressible and the volumetric flow rate remains constant. The problem statement doesn't make those assumptions so I will. In the real world, and making those assumptions, there would be a pressure difference across the pipe due to friction affects and an increase of kinetic energy, however the velocity would remain the same as an ideal fluid. This is of course assuming constant volumetric flow rate.
  • · Replies 19 ·
  • · Replies 32 ·
  • · Replies 16 ·
  • · Replies 21 ·
