The Solution Sets for linear equations in three variables
The problem involves finding the set of points that map to the point (1, -1, -1) through a specified linear transformation represented by a matrix. The context is within the subject area of linear algebra, specifically dealing with linear equations in three variables.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to understand the infinite solution scenario arising from the matrix reduction. Some participants suggest eliminating variables and expressing others in terms of parameters. Others inquire about the reduced row echelon form of the matrix to facilitate further assistance.
The discussion is ongoing, with participants providing guidance on how to approach the problem, particularly regarding the reduction of the matrix and the use of parameters. There is no explicit consensus yet, as the original poster continues to seek clarity on their attempts.
The original poster references a specific textbook and examples, indicating a structured approach to understanding the problem. There is mention of a potential misunderstanding regarding infinite solutions, which remains a point of exploration in the discussion.
takercena
This is from Further Pure Mathematics by L. Bonstock S. Chandler and C. Rourke (question 11 pg 113). The question is find the set of points which are mapped to the point (1, -1, -1) by the transformation
[tex] \left(<br /> \begin{array}{ccc} <br /> 1 & -2 & 4 \\<br /> 3 & 4 & 6 \\<br /> 1 & 3 & 1 \\<br /> \end{array} <br /> \right) <br /> <br /> \right.<br /> <br /> \left(<br /> \begin{array}{c} <br /> x \\<br /> y \\<br /> z \\<br /> \end{array} <br /> \right) <br /> <br /> =<br /> <br /> \right.<br /> <br /> \left(<br /> \begin{array}{c} <br /> X \\<br /> Y \\<br /> Z \\<br /> \end{array} <br /> \right) <br /> [/tex]
2. The attempt at a solution
I found that the equation have infinite solution since the matrix will give 0 in column 1 by using reduction method. And that's the problem because I still don't understand how to solve the infinite solution problem. I try to compare from the example from this book,
x - y + z = 4
2x + y - 2z = 1
5x - 2y + z = 13
eq 1 and eq 2 give z = 3x - 5
eq 2 and eq 3 also give z = 3x - 5
and by substitution into the first equation
z = (1/4)(3y + 7)
Hence 3x - 5 = (3y + 7)/4 = z
Still, no success.
Hi takercena!
Nicely set-out problem … :smile:
I assume you've got to 5y = 3z - 2.
Now eliminate z from (say) the second line.
That gives you another equation for y. :smile:
Well you should post the reduced row echelon form of the matrix then we can help you more explicitly. As it is, all I can tell you is to first reduce it to the RREF form, then let one of the variables x,y,z be a parameter and try to express the rest in terms of that.
[tex] \left( <br /> \begin{array}{ccc} <br /> 0 & -5 & 3 \\<br /> 3 & 14 & 0 \\<br /> 0 & 5 & -3 \\ <br /> \end{array} <br /> \left|<br /> \begin{array}{c}<br /> 2 & -5 & -2 \\<br /> \end{array}<br /> \right)[/tex]
By the way, I already get it. The answer is y/3 = (z-2)/3 = (x+(5/3))/-14. Thanks both of you
  • · Replies 19 ·
