| Thread Closed |
two easy questions |
Share Thread | Thread Tools |
| Aug15-08, 01:29 PM | #1 |
two easy questions
(1) From the length contraction equation, would [tex](L\sqrt{1-(v/c)^2} )^3[/tex] give the coordinate volume of an object?
Here's the mass equation: [tex]M=\frac{m_0}{\sqrt{1-(v/c)^2}}[/tex] My second question is ultimately about the 'speed limit' of the universe. As seen by an observer, an object's mass will approach infinity as its velocity approaches c. From this we can say that, as seen by an observer, it will take a force equal to infinity to accelerate the object to c, and because it's impossible for anything to apply that force, we say that the speed limit of the universe is c. For the most part this makes perfect sense. As seen by an observer, an object approaching a velocity of c would experience the fallowing: length approaching zero, time approaching infinity, mass approaching infinity etc. This can be easily visualized, as something approaches c, it escapes more and more light, and in theory, if it reached c, the object would vanish, in turn revealing a zero length, infinite time, and a questionably visualized infinite mass. But what about the proper variables? They don't change with an increase in velocity. Mass, time, and length, by definition, don't change in the object's inertial frame. The object keeps its own rest mass. This is my main point as the 'speed limit' was initially set because the object's coordinate mass approaches infinity, but now I'm saying that an object's mass doesn't change in its inertial frame. That being said, I think it's obvious that the energy required for an object to accelerate itself to c, is in fact finite. Keep in mind, it's very important that the force be applied from within the object's inertial frame. If the force was applied from outside of the frame, it would take an infinite force for the object to reach c. The speed limit of c holds very true in special relativity. In theory, an observer will NEVER see an object traveling at or faster than c, for more than one reason. To be honest, I see no proof that the speed limit of c holds true in all cases. Obviously there is no proof that faster than light travel is possible, but even if it was very possible, we still wouldn't be able to observe that. To conclude, in theory, an object can reach the speed of light or greater with a finite force applied to itself from within its inertial frame. (2) Why wouldn't this statement be true? (whether or not we know how to initiate the above bolded phrase, doesn't change the theoretical case) |
| Aug15-08, 01:57 PM | #2 |
Mentor
1. No, you don't take 1/gamma to the third power, since the length contraction is just in one direction.
2. I can't make sense of the bolded phrase. What would it mean to apply a force within the inertial frame? It sounds like you're going to pull your own hair or something. If you mean that you're going to do something that gives you a constant proper acceleration, that's not enough to get you to reach the speed of light. |
| Aug15-08, 02:26 PM | #3 |
We say you can't accelerate an object to c because the relativistic mass demands a force of infinity to do so. But what if the mass I wanted to accelerate wasn't relativistic at all, if I could "somehow" accelerate myself, it would only take a finite amount of energy to reach c. In this special case, I am my own observer so my rest mass is constant to me, and thus requiring finite energy. I'm just trying to show that in theory, nothing (yet), stops an object in its inertial frame from obtaining a velocity of c in this way. |
| Aug15-08, 02:43 PM | #4 |
two easy questionsA rocket with a constant thrust will never reach the speed of light with respect to another object. Not even in the limit because the hyperbolic velocity addition function does in fact have no limit. |
| Aug15-08, 03:07 PM | #5 |
Mentor
It's not just that I don't know how to accomplish what you're suggesting. It's that I don't know what you're suggesting. I don't think there's any way to make sense of it.
What if I e.g. run behind you and give you a push once per second according to your clock. Even if we ignore the practical problems and how out of shape I am, you would still at best approximate the world line of an object with constant proper acceleration, and constant proper acceleration is definitely not enough to reach c. |
| Aug15-08, 03:52 PM | #6 |
There is no clear example that we could grasp, I already admitted that. Trying to find an example may or may not be hopeless. If applied a constant force per time on a rock, its acceleration would drop as its velocity approached c. That's an example of a force from outside of the inertial frame of an object, and becuase it's from outside of the inertial frame, we must use relativistic mass transformation to calculate the mass. If we are bounded to using the relativistic mass tansformation, then we no object with rest mass greater than 0 will ever travel at c or faster. So ask yourself, when are we not bounded to using the relativistic mass transformation? The answer is, when you are the object, when you are in the inertial frame, when you are observing yourself. Being the object in the inertial frame, we don't use the relativistic mass transformation, we use a simple m_0 = M. This is where you are getting confused. Because you are the object in the inertial frame, and you are supposed to be applying a force, you need to "somehow" apply a force to yourself. (what ever that means, I could be very possibly using the wrong words to describe; there is no example of this thus far) So, as you "apply a force to yourself" per time, you gain acceleration, and because your mass is not relative to your velocity, the amount of energy needed to accelerate you to c or more is finite. [tex]E=M_c*c^2[/tex] M_c signifies that the mass is constant for all v. |
| Aug15-08, 04:04 PM | #7 |
Mentor
Please note: while the acceleration can be viewed from your frame only, velocity only exists when viewed between two frames. You can't escape the fact that you'll always measure your velocity to be below C.
| Aug15-08, 04:33 PM | #8 |
Mentor
If you want to invent a magical universe where momentum is not conserved then you are certainly free to decide that in your fantasy-land c won't be a limiting speed either. |
| Aug15-08, 06:22 PM | #9 |
Mentor
| Aug15-08, 07:46 PM | #10 |
It sounds like the OP is thinking about "proper velocity", not relative velocity. Proper velocity is momentum/mass, so it it not limited to c. There's plenty of info on the net about proper velocity, but for most purposes, it's not very useful.
Al |
| Aug15-08, 08:44 PM | #11 |
Mentor
I have never heard of the term "proper velocity". Wouldn't that always be 0?
| Aug15-08, 09:36 PM | #12 |
![]() i think it would be, Dale. |
| Aug15-08, 09:58 PM | #13 |
There is plenty of info about it on the net, but it's normally not very relevant. Al |
| Aug15-08, 10:00 PM | #14 |
As far as violating the conservation of momentum, I haven't even suggested an example yet, so you can't really assume so. One possible idea to get around this, off the top of my head, is some collision with light in a way where energy is transferred to you, but because the light's rest mass is zero, the negative 'action' that is demanded by the conservation of momentum would cancel out, therefore holding the conservation of momentum. (please do not quote this example) Bolded phrase is my main point of this topic. |
| Aug15-08, 10:09 PM | #15 |
Al |
| Aug15-08, 10:13 PM | #16 |
Mentor
| Aug15-08, 10:18 PM | #17 |
Mentor
Thanks Al, it is nice to know that I can learn something even in the silliest threads! |
| Thread Closed |
| Thread Tools | |
Similar Threads for: two easy questions
| 6 Easy Questions | Introductory Physics Homework | 4 | ||
| Guys, I have 4 easy questions. (probably easy to you) | Introductory Physics Homework | 32 | ||
| Easy questions that I need help with! | Introductory Physics Homework | 5 | ||
| Easy questions. | Introductory Physics Homework | 15 | ||
| Easy Questions - Plz Help | Introductory Physics Homework | 3 | ||
