Partial Fractions Exam: Double Root Question?
The discussion revolves around a partial fractions problem encountered in the context of an exam preparation. The original poster describes a scenario involving a double root in the denominator, specifically the expression (1/(y+c)(y+c)), and questions how this affects the approach to solving the problem.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the implications of having a double root in partial fractions, with some suggesting that it changes the form of the solution. Questions arise regarding the validity of the proposed forms and whether they lead to meaningful results. There is also a discussion about logarithmic properties and their application in integration.
The conversation is ongoing, with participants exploring different interpretations of the problem. Some guidance has been offered regarding the form of the solution, but there is no explicit consensus on the correct approach or outcome. Participants are actively questioning assumptions and clarifying mathematical concepts.
There are indications of confusion regarding logarithmic laws and integration techniques, as well as the handling of expressions involving squared terms. Participants express uncertainty about the implications of these mathematical properties in their specific context.
franky2727
got an exam coming up in a few days and half way through my question i ran into a partial fractions question instead of having the standard (1/(y+c)(y+d))= A/(y+c) + B(y+d) and multiplying out i had a double root so (1/(y+c)(y+c)) does this change the way i go about the question and are there any other similar situations that i am likely to run into?
Although it shouldn't affect the method you use, it will affect the form of your solution. In this case your solution will be of the form:
[tex]\frac{1}{\left(y+c\right)^2} = \frac{A}{y+c\right} + \frac{B}{\left(y+c\right)^2}[/tex]
i.e. a linear denominator followed by a quadratic denominator. You should then follow your usual technique (e.g. equating coefficients) to solve for A and B.
are you sure this is right cos this gives me A=0 and B=1 giving me 1/(y+c)^2=1/(y+c)^2 which doesn't achive anything at all
Hi franky2727! :smile:
(since Hootenanny is offline …)
This is really for fractions like (P + Qy)/(y + c)2,
and it gives you partial fractions of the form A/(y + c) + B/(y + c)2, without any y on top.
In this case, you started without any y on top, so indeed you didn't achieve anything at all, because 1/(y + c)2 was already the simplest answer. :wink:
Ahh.. ok so i just end up with Ln|(y+c)^2|?
erm … if you started with ∫dy/y2 (you didn't say), then nooo … :frown:
ln(y + c)2 is just 2 ln(y + c), isn't it? :wink:
i feal so stupid :P log laws a bit rusty to say the least
the log law is not the problem here.
[tex]\int \frac{1}{y^2}dy= \int y^{-2} dy[/tex]
is NOT a logarithm.
no i started with dy/(v+1)2
so am i right to get ln |(v+1)2| and does that go to 2ln|V+1| i thought it wouldn't because the squared bit is inside the modulus not outside or does that not matter because squaring something gets rid of the need for a modulus anyway
so what does this end up as when i e-it-out (V+1)^2 or 2(V+1) or something different
Nooo …
Hint: what do you have to differentiate to get -1/x2? :smile:
(V+1)^2 :smile:
is this even ment to be in logs ? 1/((V+1)^2 can be (V+1)^-2 which goes to (-1/V+1)?
Bingo! :smile:
