How Do You Solve the Trigonometry Equation cos4x - 7cos2x = 8?
  • Thread starter Thread starter Geekchick
    Trig
The problem involves solving the trigonometric equation cos4x - 7cos2x = 8 within the interval [0, 2π). Participants are discussing various trigonometric identities and formulas relevant to the problem, including double angle formulas and their applications.
  • Participants explore the use of double angle formulas and express confusion about how to apply these when dealing with cos4x. There are attempts to rewrite cos4x in terms of cos2x and questions about the validity of their transformations. Some participants suggest factoring the equation after rewriting it.
The discussion is ongoing, with participants providing guidance on rewriting the equation and factoring. Some have noted the potential for no solutions based on the values derived from the cosine function, while others are still working through the implications of their calculations.
Participants mention constraints such as the interval for the solutions and the challenge of working independently in a summer course. There is also a reference to the need for clarity in understanding the properties of trigonometric functions, particularly regarding their ranges.
Geekchick
cos4x-7cos2x=8 solve in interval [0,2[tex]\pi[/tex])
reciprocal identities, pythagorean identities, sum/difference formulas, double angle formulas, power reducing formula, half-angle formula, product to sum formula, sum to product formula.
So to solve this problem I am pretty sure I will have to use the double angle formula. However, I am a little confused as to how the formula changes when you have more than 2x. the only additional example my textbook gives it Cos6x=cos[tex]^{}2[/tex]3x-sin[tex]^{}2[/tex]3x. So from that I can assume that cos4x= cos[tex]^{}2[/tex]2x-sin[tex]^{}2[/tex]2x. But how would cos2x=2cos[tex]^{}2[/tex]x-1 change when its cos4x? I got my problem down to:
cos4x-14cos[tex]^{}2[/tex]x-15
I'm hoping that if I can expand on cos4x then I can maybe factor...or am I going about this all wrong.
Please help, I hate to be a bother but I'm taking this Pre-cal class independently over the summer and have already got an incomplete grade. My teacher said I have until the 20th to finish all the test and labs, so I'm trying to tie up all my loose ends so I can be done and move onto calculus.
Thanks
Ok well let's say we have [tex]cos(2y) = 2cos^2(y) - 1[/tex]. Now to get [tex]cos(4x)[/tex], let [tex]y=2x[/tex]. It should make sense now. I used to have the same problem, which kind of goes back to functions. But if you think about it a little it shouldn't be hard to work out.
I get what you are saying, but I still cannot solve the problem. :confused:
You have the right idea. Write everything in terms of [tex]cos(2x)[/tex]and constants. Then see if you move everything one side and factor.
Ok, so this is what I have done.
cos4x-7cos2x=8
seeing as cos4x=2cos22x-1
then
2cos22x-7co2x-9
When I factor that I get
(2cos2x-9)(cos2x+1)
Right so far?
then when I set each to zero I get
2cos2x=9
Here is where I'm a little confused. Does it go like this?
cos2x=9/2
cosx=9/4
or is it
cosx=9/2
all of these twos are throwing me lol
With the other one I get
cos2x=1
cosx=1/2
But another issue is when I plug the problem into my calculator and graph I end up with the answer being [tex]\pi[/tex]/2 and 3[tex]\pi[/tex]/2 implying that the answer is cosx=0 unless I am just having issues with my calculator which happens from time to time.
thanks
(2cos2x-9)(cos2x+1)
Right so far?
OK up to here...
2cos2x=9
cos2x = 9/2
This is correct. And this should instantly tell you that this case has no solution, as there is no angle (doubled or otherwise) which has a cosine larger than 1...
cosx=9/4
or is it
cosx=9/2
Neither of these is correct. It is not the case that cos(nx) = n cos(x) ; you cannot simply pull constant factors out of the argument of a trig function -- those constants are multiplying the angle and will not similarly multiply the trig function.
cos2x=1
cosx=1/2
There is also a problem here. Your result for this case is (cos2x+1) = 0 , which gives
cos 2x = -1.
Again, you cannot just pull that '2' out of the argument of cosine: it is not something called cosine times 2x, but a function called cosine applied to the angle (2x).
The way you solve this is to ask what angles have a cosine of -1 (equivalently, we would solve 2x = arccosine(-1) ). We need all the angles in the interval [0, 2·pi), so we would look at
2x = (pi) , 2x = 3(pi), 2x = 5(pi), ... ,
which gives us
x = (pi)/2 , x = 3(pi)/2 [and that's it: everything beyond that is outside the specified domain]. Since the other factor gave no other solutions, these are the only ones.
As a check (which you should always do when working with trig equations), we find
cos4x - 7cos2x = 8
x = (pi)/2 : cos(2·pi) - 7·cos(pi) = 1 - 7·(-1) = 8 (check!)
x = 3(pi)/2 : cos(6·pi) - 7·cos(3·pi) = 1 - 7·(-1) = 8 (check!)
  • · Replies 42 ·
  • · Replies 25 ·
  • · Replies 21 ·
