Is the ds² Expression for a Uniform Gravitational Field Correct?
The discussion centers around the validity of the expression for the metric of a uniform gravitational field, specifically the equation ds² = (1+gz/c²)²(cdt)² - dx² - dy² - dz². Participants explore its implications for time dilation and the relationship between escape velocity and time dilation in different gravitational contexts.
  • One participant questions the correctness of the metric expression, noting it leads to a different time dilation relationship than expected based on escape velocity considerations.
  • Another participant suggests that the escape velocity/time dilation relationship may not apply to metrics other than the Schwarzschild metric, prompting a request for clarification on its derivation.
  • A participant discusses the potential for escape velocity to be defined differently in the context of a rotating disk, proposing a universal relationship between escape velocity and time dilation.
  • One participant introduces the concept of Rindler spacetime, indicating that the idea of escape velocity may not be meaningful in this context due to the nature of constant acceleration.
  • Another participant clarifies their definition of escape velocity in a constant gravitational field, suggesting a specific formula for time dilation that they believe applies universally, but expresses uncertainty about its validity in the Rindler metric.
  • A follow-up question is posed regarding the solution to an equation of motion under constant acceleration, with participants discussing potential functions that could satisfy the equation.
  • A later reply corrects an earlier claim about the equation of motion, indicating a misunderstanding regarding the proper acceleration and coordinate acceleration relationship.
Participants express differing views on the applicability of the escape velocity/time dilation relationship to the discussed metric, with no consensus reached on its validity or derivation. The discussion remains unresolved regarding the implications of the Rindler metric and the correct interpretation of escape velocity in this context.
There are limitations in the assumptions made about the escape velocity relationship, particularly regarding its applicability to different metrics. The discussion also highlights unresolved mathematical steps related to the equation of motion under constant acceleration.
snoopies622
I just came across this expression
[tex]ds^2 = (1+gz/c^2)^2(cdt)^2 - dx^2 - dy^2 - dz^2[/tex]
in entry #19 of this thread https://www.physicsforums.com/showthread.php?t=227753[/URL] for the metric of a uniform gravitational field. Is this correct? I was wondering because it yields
[tex]\frac{d\tau}{dt}=(1+\frac{gz}{c^2}) [/tex]
for a stationary clock, but if
[tex]\frac{d\tau}{dt}=\sqrt{1-\frac{v_{esc}^2}{c^2}}
[/tex]
between any two points of different gravitational potential, then we should get
[tex]\frac{d\tau}{dt}=\sqrt{1-\frac{2gz}{c^2}}[/tex]
instead. Here z=0 is the ceiling of the elevator/spaceship and z>0 as we move towards the floor, but even if we switch that around (so that z=0 is the floor and z>0 as we move towards the ceiling) it doesn't explain what happened to the "2" or the radical sign.
Can someone point out the flaw(s) in my reasoning? Is the escape velocity/time dilation relationship not applicable here? Thanks.
I haven't had time to look at this, and I'm just going out the door for a walk with my wife and daughter, but I'll take a stab at it.
Are you using the escape velocity/time dilation relationship from the Schwarzschild metric? There is no reason for this relationship to hold for a metric that isn't the Schwarzschild metric metric.
If the relationship isn't from Schwarzschild, where is it from? How is it derived?
George Jones said:
..the escape velocity/time dilation relationship...where is it from?
If you take the potential difference between the edge of a rotating disk and its center and convert that into an 'escape velocity' you get the velocity of that point on the disk, which (I thought) gives you the time dilation via the SR equation (the Lorentz factor). Since it works for both this case and Schwarzschild (the relationship between escape velocity and time dilation) I thought it was universal.
Perhaps that was the flaw right there.
The metric you've quoted is a species of the Rindler spacetime, which is in constant acceleration. I'm not sure if the idea of escape velocity has meaning in this case.
There's a singularity at g00=0, so I suppose you could calculate the velocity of a particle that falls from infinity to the singularity.
By the 'escape velocity' between two points I just meant the vertical speed at which something at the lower point would have to be thrown so that the peak of its trajectory would be at or next to the higher point. So for example in a constant gravitational field with acceleration [tex]g[/tex], the 'escape velocity' between two points of height difference [tex]\Delta h[/tex] would be [tex]v_{esc}=\sqrt{2g \Delta h}[/tex]. I understand that this is not how the phrase is normally used (unless the upper height is [tex]\infty[/tex]) but I don't know what else to call it. Anyway, for a while I've believed that for any gravitational field, between any two different heights
[tex]\frac{d\tau}{dt}=\sqrt{1-\frac{v_{esc}^2}{c^2}}[/tex]
using the definition of [tex]v_{esc}[/tex] that I just gave, since this seems to be the case both with the Schwarzschild metric and a clock on a rotating disk. But if it's not true for the Rindler metric then I'll forget about it altogether.
A follow-up - if I may - regarding constant acceleration:
If a constant force is applied to an object of rest mass [tex]m_0[/tex], then
[tex] \frac{dv}{dt}=\frac{F}{m_0}\sqrt{1-\frac{v^2}{c^2}}[/tex].
Question: What function v(t) is a solution to this equation? Both arc tangent and hyperbolic tangent seem to have about the right shape, but unless there's a trig identity regarding arc tangent that I'm not aware of, neither of them work.
See this thread, in particular post #19 (and the links there to another thread) and post #22.
You will see that your equation is wrong, it should be [itex]\gamma^{-3}[/itex] rather than [itex]\gamma^{-1}[/itex]. [itex]F/m_0[/itex] is the proper acceleration, [itex]dv/dt[/itex] is the coordinate acceleration.
Thanks, DrGreg. I forgot about the effective-mass-being-different-in-different-directions business.
  • · Replies 0 ·
  • · Replies 40 ·
  • · Replies 26 ·
