Question on moment of inertia of multiple bodies
The discussion revolves around the calculation of the moment of inertia (MOI) for two unequal masses rotating about an axis. Participants explore the implications of their positions relative to the axis and the role of the center of mass in determining the MOI.
  • Technical explanation, Debate/contested
  • One participant suggests that the MOI can be calculated using the center of mass and its distance from the rotation axis, but acknowledges a potential flaw in this assumption.
  • Another participant clarifies that the MOI is calculated about the axis of rotation rather than the center of gravity (CG), and mentions the concept of polar MOI.
  • A different participant emphasizes that the MOI of a composite body cannot be simplified to the product of total mass and the square of the distance from the axis to the center of mass without considering the parallel axis theorem.
  • A later reply indicates that the initial confusion has been resolved, but does not elaborate on the specifics of the resolution.
Participants express differing views on the relationship between the center of mass and the calculation of MOI, indicating that multiple competing perspectives remain unresolved.
There are limitations regarding the assumptions made about the distances involved and the definitions of the axes of rotation and center of mass, which are not fully clarified in the discussion.
jasc15
My boss and i were considering he following problem (see attached image):
2 unequal masses rotate an equal distance, r, about an axis. We both agreed that regardless of their angular position from each other (wether they were diametrically opposed or otherwise oriented, the 2 examples shown in the image) is not relevant to their moment of inertia. However, you should be able to calculate the MOI using their center of mass and its distance, x, from the rotation axis. There is obviously something wrong with this assumption, since r and x are not equal. Can someone shed some light on this? Also, I am ignoring their centroidal mass moments.
the MOI is about an axis of rotation. Not about the CG. (Well, it can be if you take the distances about the CG).
They should be the same to me. What you have in your example is the polar MOI.
I would expect the case where the CG is furthers from the axis of rotation (O) to have the most rotational imbalance.
The MOI of a composite body about some axis does not simply = (total mass)*(distance from axis to center of mass)^2. To use the center of mass, you have to first find the MOI of the composite body about its center of mass and then use the parallel axis theorem to get the MOI about the desired axis. Do it properly and you'll find that you get the same total MOI this way or by just adding the individual MOIs.
Thanks for the help. I got it
  • · Replies 30 ·
  • · Replies 69 ·
  • · Replies 30 ·
