What is the sum of this geometric series?
  • Context: Undergrad
  • Thread starter Thread starter greenandblue
    Series Sum
The discussion revolves around the convergence of a specific geometric series and the calculation of its sum. Participants explore different approaches to determine whether the series converges and how to compute the sum if it does.
  • Homework-related
  • One participant presents the series \(\sum^{\infty}_{n=1}\frac{7^n+3^n}{8^n}\) and questions its convergence and the method to find its sum.
  • Another participant suggests that the series can be separated into two geometric series: \(\sum^{\infty}_{n=1}(\frac{7}{8})^n\) and \(\sum^{\infty}_{n=1}(\frac{3}{8})^n\).
  • A third participant expresses surprise at the idea of summing the individual series and thanks the previous contributor for the clarification.
  • One participant raises a question about the significance of the series being 1-relative and whether it is necessary to adjust the formula to account for the missing \(n=0\) term.
  • Another participant responds by discussing the formula for the sum of a geometric series and explains how to adjust for the missing term, suggesting that factoring out a term can lead to the same result.
Participants do not reach a consensus on the necessity of adjusting the series for the missing term, and there are differing views on the approach to summing the series. The discussion remains unresolved regarding the best method to handle the series.
There are unresolved questions about the implications of the series being 1-relative and the necessity of converting the series to a different form for summation. Additionally, the participants do not clarify the conditions under which the series converges.
greenandblue
1. Homework Statement :
The following is a geometric series.
Determine whether series is converges or not.
For the series which converge, enter the sum of the series
[tex]\sum^{\infty}_{n=1}\frac{7^n+3^n}{8^n}[/tex]
2. The attempt at a solution:
I've looked into calculating [tex]{r}=\frac{a_{n+1}}{a_{n}}[/tex] but the series isn't constant and neither is r : [tex]\frac{10}{8}{+}\frac{58}{64}{+}\frac{185}{256}{+...}[/tex]
I feel like there is another approach to solving this problem that I am missing. Your help is appreciated, thanks.
Well it's just the sum of two geometric series isn't it?
[tex] \sum^{\infty}_{n=1}(\frac{7}{8})^n + \sum^{\infty}_{n=1}(\frac{3}{8})^n[/tex]
I ran those numbers through on paper before too, but it never clicked that I could find the sum individually and add them together. Thanks for your help.
does it matter that the series is 1-relative? i.e. does one need to convert to make r^(n-1)?
j
Good point.
[tex]\sum_{n=0}^\infty a r^n= \frac{a}{1- r}[/tex]
Here, since it is missing the "n= 0" term, you just subtract that term of: ar0= a so
[tex]\sum_{n=1}^\infty a r^n= \frac{a}{1- r}- a= \frac{a}{1-r}- \frac{a- ar}{1-r}= \frac{ar}{1- r}[/tex]
Of course, that is exactly the same as if you had just factored out an "r":
[tex]\sum_{n=1}^\infty ar^n= \sum_{n= 1}^\infty (ar)r^{n-1}= \sum_{j= 0}^\infty (ar)r^j[/itex]<br /> where j= n-1 so that when n= 1, j= 1-1= 0.[/tex]
