Definition of short- and long-distance effects in branching ratios
The discussion clarifies the distinction between short-distance and long-distance contributions to branching ratio calculations in particle physics, particularly in the context of K-Kbar mixing within the Standard Model. Short-distance effects arise from heavy quarks, such as top and charm, which are perturbative due to their high virtuality and the asymptotic freedom of Quantum Chromodynamics (QCD). In contrast, long-distance contributions stem from light quarks, like up quarks, which are non-perturbative and can be interpreted as contributions from pions, representing the infrared limit of QCD. This understanding is crucial for accurate calculations in particle physics research.
  • Understanding of Quantum Chromodynamics (QCD)
  • Familiarity with particle physics concepts, specifically K-Kbar mixing
  • Knowledge of perturbative and non-perturbative effects
  • Basic grasp of the uncertainty principle in quantum mechanics
  • Research the role of heavy quarks in perturbative QCD calculations
  • Study the implications of the uncertainty principle on particle lifetimes
  • Explore the concept of infrared limits in Quantum Chromodynamics
  • Investigate the effects of light quark masses on particle interactions
Particle physicists, researchers in theoretical physics, and students studying Quantum Chromodynamics and branching ratio calculations will benefit from this discussion.
jossives
Would somebody be kind enough to explain what exactly is meant when discussing short- or long-distance contributions/effects to branching ratio calculations?
Hmmm... I think it depends on the context. For example, something I've been thinking about recently for my research: in K-Kbar mixing in the Standard Model, you can have effects from heavy quarks and light quarks running through loops. The heavy quarks are highly virtual (such as the top and charm) and so, thanks to the asymptotic freedom of QCD, these contributions are perturbative. However, the contribution from the light quark masses (up) is definitely not perturbative, since these quarks are quite light and are not "as virtual" as the heavy quarks. This means that they can exist longer from the uncertainty principle, and this means that the contributions from light quarks is ACTUALLY a contribution from pions, the IR limit of QCD. These are called "long-distance" contributions, and cannot be computed with perturbative QCD.
Hope that helps.
Perfect. That was exactly the explanation I was looking for. Thanks blechman
  • · Replies 19 ·
  • · Replies 0 ·
  • · Replies 31 ·
