What is the Origin of the Spatial Metric in Non-Inertial Frames?
  • Context: Graduate
  • Thread starter Thread starter jdstokes
    Metric Origin
The discussion revolves around the origin of the spatial metric used for measuring distances in non-inertial frames, specifically the expression d\ell^2 = [(g_{0i}g_{0j})/g_{00} - g_{ij}]dx^i dx^j. Participants explore theoretical foundations, derivations, and implications of this metric in the context of general relativity and the concept of radar distance.
  • One participant requests an explanation of the origin of the spatial metric and expresses confusion about its derivation and assumptions regarding distance as half the proper time for the return of an electromagnetic signal.
  • Another participant proposes a derivation involving the metric components and null geodesics, but concludes that their result is incorrect.
  • A different participant suggests that the metric measures distances within surfaces orthogonal to the worldlines of observers, and discusses the decomposition of differentials in relation to the observer's 4-velocity.
  • One participant asserts that the expression represents radar infinitesimal spatial distance and references a derivation in an appendix, indicating some support for the previous claims.
  • A later reply acknowledges an error in a previous derivation related to radar distance, specifically regarding the treatment of time components in the calculation.
Participants express various interpretations and derivations of the spatial metric, with some agreeing on its relation to radar distance while others present differing views on its derivation and implications. The discussion remains unresolved with multiple competing perspectives.
There are unresolved assumptions regarding the derivation of the spatial metric and its dependence on the definitions of distance and proper time. The discussion also highlights potential errors in mathematical steps without reaching a consensus on the correct approach.
jdstokes
Can anyone explain to me the origin of the spatial metric for measuring distances in non-inertial frames?
[itex]d\ell^2 = [(g_{0i}g_{0j})/g_{00} - g_{ij}]dx^i dx^j[/itex].
I've heard it quoted but never seen it derived. I believe it works on the assumption that distance is half the proper time for return of an em signal (whatever that means).
Thanks.
My best guess:
[itex]ds^2 = g_{00} c^2 dt^2 + g_{ij}dx^{i} dx^{j} + 2g_{0i} cdt dx^i[/itex]
[itex]c^2 d\tau^2 = g_{00} dt^2[/itex]
On null geodesics
[itex]0 = g_{00} c^2 dt^2 + g_{ij}dx^{i} dx^{j} + 2g_{0i} cdt dx^i \implies[/itex]
[itex]c dt = -\frac{g_{0i} dx^i}{g_{00}} \pm \frac{\sqrt{g_{0i}g_{0j}dx^i dx^j - g_{00} g_{ij} dx^i dx^j }}{g_{00}}[/itex] (quadratic equation)
Now [itex]d\ell =c\frac{1}{2}d\tau = c\frac{1}{2}\sqrt{g_{00}}(dt_++dt_-) = \frac{g_{0i}dx^i}{g_{00}} \implies[/itex]
[itex]d\ell^2 = \frac{g_{0i}g_{0j}dx^i dx^j}{g_{00}}[/itex]
which is wrong.
I've never seen this before, but a little thought suggests the following.
I think we have to assume that the curves [itex]dx^1=dx^2=dx^3=0[/itex] represent worldlines of observers and I think the metric you quoted measures distance within the surfaces that are orthogonal to those worldlines.
If [itex]U^{\alpha}[/itex] is parallel to the 4-velocity of such an observer, with components (1, 0, 0, 0), consider decomposing [itex]dx^{\alpha}[/itex] as
[tex]dx^{\alpha} = dP^{\alpha} + dQ^{\alpha}[/tex]​
where [itex]dP^{\alpha}[/itex] is parallel to [itex]U^{\alpha}[/itex] and [itex]dQ^{\alpha}[/itex] is orthogonal to it. The orthogonality ensures that
[tex]dx_{\alpha}dx^{\alpha} = dP_{\alpha}dP^{\alpha} + dQ_{\alpha}dQ^{\alpha}[/tex]​
The required projection is given by
[tex]dP^{\alpha} = \frac{U_{\beta}U^{\alpha}}{U_{\gamma}U^{\gamma}}dX^{\beta}[/tex]​
and then I think it all follows from that, noting that
[tex]U_{\beta} = g_{\beta \alpha} U^{\alpha} = g_{\beta 0}[/tex]​
and the answer you want is [itex]d\ell^2 = dQ_{\alpha}dQ^{\alpha}[/itex].
That would be "radar distance" which amounts to the same thing infinitesimally, but not over larger distances (except in flat spacetime).
[tex]d\ell^2 = [(g_{0i}g_{0j})/g_{00} - g_{ij}]dx^i dx^j[/tex]
It is the radar infinitismal spatial distance. There's a good derivation in appendix A of the attached.
DrGreg's derivation is along the right lines but I haven't checked it.
M
Hi DrGreg,
You're correct, the metric is actually the same thing as the projection operator [itex]U^\alpha U^\beta - g^{\alpha\beta}[/itex], written in the frame where the observer has vanishing 3-velocity.
The error in my derivation of radar distance was to add [itex]dt_+,dt_-[/itex] when I should have subtracted them. This is because one of them gives a time into the past which is negative.
  • · Replies 46 ·
  • · Replies 21 ·
  • · Replies 27 ·
