Integrate Over XY Plane for Simplest Partial Derivatives
The discussion focuses on integrating over the XY plane to simplify the calculation of partial derivatives, specifically when dealing with functions expressed as z = f(x, y). It clarifies that for effective integration, the surface must project one-to-one onto the chosen plane. The conversation also highlights the importance of using parametric equations, such as x = f(u, v), y = g(u, v), and z = h(u, v), for more complex surfaces. Understanding these principles is crucial for accurately determining areas and derivatives in multivariable calculus.
  • Understanding of multivariable calculus concepts
  • Familiarity with partial derivatives
  • Knowledge of parametric equations
  • Experience with surface integration techniques
  • Study the method of integrating functions over surfaces in multivariable calculus
  • Learn about the application of parametric equations in surface integration
  • Explore the relationship between partial derivatives and surface areas
  • Investigate the use of Jacobians in changing variables during integration
Students and professionals in mathematics, particularly those studying multivariable calculus, as well as educators teaching integration techniques and partial derivatives.
coverband
which will yield the simplest partial derivatives
i.e. integrate over the xy plane if dz/dx and dz/dy yield the simplest expression?
I don't understand your question. What function (be it scalar or vector) are you integrating over and how is it expressed?
Are you talking specifically about finding the area of a surface? Just integrating a function over a surface doesn't necessarily have anything to do with the derivatives.
Basically, you just have to be sure that the surface projects one-to-one onto the plane you are using. As long as the surface is given by the function z= f(x,y), you can be sure the xy-plane will work. If the surface is given by x= f(y,z) or y= f(x,z) then the yz-plane and xz-plane, respectively will work. More generally, if you can write the surface with parametric equations, x= f(u,v), y= g(u,v), z= h(u,v) with f, g, and h functions, then you can integrate over the "uv-plane". If z= f(x,y), then x= x, y= y, z= f(x,y) are parametric equations with "parameters" x and y.
