Light speed relative to accelerating & const vel source
The discussion revolves around the behavior of light signals emitted by two observers, one accelerating and the other moving at constant velocity, and how their relative motions affect the arrival times of these signals. The scope includes conceptual and theoretical considerations of relativity and the nature of simultaneity in different frames of reference.
  • One participant questions whether the time T for the signal to arrive is the same for both observers, emphasizing that T is frame-dependent due to B's acceleration.
  • Another participant asserts that the time depends only on the distance, suggesting a straightforward interpretation of the scenario.
  • A later reply introduces the idea that time is not the same for accelerating and non-accelerating observers, prompting further clarification on the role of the observer's frame of reference.
  • One participant highlights the need to specify the frame of reference to determine the time and distance accurately, indicating that the answer may differ based on the chosen frame.
  • Another participant discusses the application of the time dilation formula, noting its limitations when events do not occur at the same location in a given frame.
  • One participant clarifies that if two transmitters send signals simultaneously from the same position, the signals will arrive simultaneously at the observer, regardless of the transmitters' states of motion.
Participants express differing views on the impact of acceleration on the arrival times of signals, with some asserting that the time is frame-dependent while others argue for a more straightforward interpretation based on distance. The discussion remains unresolved regarding the implications of acceleration on simultaneity and the application of relativistic principles.
The discussion includes assumptions about the nature of time and simultaneity in different frames, as well as the application of relativistic equations, which may not be universally agreed upon. The definitions of time and distance in various frames are critical to the interpretations presented.
brightonb
Two observers, A & B, are moving apart at constant velocity V. At distance D, B sends a pulse to A which arrives T seconds later. If B were instead accelerating at a rate such that he attains velocity V just when he is at distance D, and sends a pulse at this instant (while still accelerating but at velocity V), would the pulse still arrive T seconds later?
Thanks for any responses, Manny
Let me start by saying I am not a physics major and am starting to try and learn this stuff so I would appreciate any skepticism in my response.
You can’t say T sec. later. You are using T as a time without any particular Frame of reference. T for the B will not be T for A. Mainly due to the fact that B is accelerating.
Yes, definitely, the time depends only on the distance.
Ah ... are you taking into account G.R... I mean time is not the same for someone accelerating compared to someone not accelerating ... Am I correct??
What I mean is WHO is holding the clock ... you?
The question is not really well-defined unless you specify what frame (coordinate system) you're using to define time and distance. If you are using A's inertial rest frame, for example, then it would make no difference whether B was accelerating when he emitted the signal, for example. But if you use an accelerating frame in which B is at rest, the answer will probably be different than it would have been if B had been moving inertially and you used B's inertial rest frame.
The time measured by A would be the same but to find that measured in any other frame in relative motion divide the time measured by A bygamma, that is 1/sqrt.(1-v^2/c^2) v is the relative velocity that gives a lesser value
That's not right, the time dilation formula only works for events which occur at the same location in frame where they are separated by a time T (for example, ticks of a clock which is at rest in that frame), then in another frame the same pair of events will be separated by a larger time T/sqrt(1 - v^2/c^2). In this example we are dealing with the time between the signal being emitted by B and the signal being received by A, which don't occur at the same location in A's frame; if the time between them in A's frame is T and the distance between them in A's frame is X then you would use the temporal part of the Lorentz contraction equation, T' = (T - vX/c^2)/sqrt(1 - v^2/c^2), to find the time T' between the events in some other inertial frame moving at speed v relative to A's frame.
To clarify this problem, what I am actually asking is whether a signal from 2 transmitters will arrive simultaneously at the observer given that one transmitter is accelerating & the other moving at constant velocity relative to the observer. The signals are sent as the 2 transmitters pass each other (i.e. from the same position).
In that case, since the signals travel at c, and they are being sent from the same spacetime event, then they arrive simultaneously at the receiver. It makes no difference whether the emitter is accelerating, at rest, moving, running in circles, or wearing its underwear on its head. Photons travel at c.
Man, I'm going to have some strange dreams tonight... :smile:
  • · Replies 42 ·
  • · Replies 22 ·
  • · Replies 33 ·
  • · Replies 30 ·
  • · Replies 45 ·
  • · Replies 67 ·
  • · Replies 33 ·
  • · Replies 26 ·
