Find a parametric equation of the line
  • Thread starter Thread starter His_Dudeness3
    Line Parametric
The discussion revolves around finding parametric equations for the intersection of two planes and calculating the distance from a point to this line of intersection. Additionally, there is a question regarding the distance between two skew lines representing the paths of two objects in space.
  • Mixed
  • Participants explore methods for finding the intersection of two planes by substituting values and solving simultaneous equations. There is discussion about the normal vectors of the planes and the use of cross products to find direction vectors for the line of intersection.
  • For the second question, participants discuss constructing a vector between points on two skew lines and finding conditions for perpendicularity to determine the minimum distance between the lines.
  • Some participants question the setup of equations and the use of dot products to find the necessary conditions for perpendicularity.
Participants are actively engaging with the problems, sharing their reasoning and calculations. There is a mix of agreement and clarification on the methods used, particularly regarding the parametric equations and the calculations for distances. Some have identified errors in their previous work and are seeking confirmation on their revised approaches.
Participants note constraints such as the need for correct application of mathematical principles and the importance of clarity in using vectors and equations. There is an emphasis on ensuring that the derived equations accurately reflect the relationships between the geometric entities involved.
His_Dudeness3
Hi, I've got these 2 questions left on an advanced Mathematics assignment (due Monday morning :( ) that I've been trying to crack but I'm not sure if what I have done is correct. Any help at all is greatly appreciated.
Question:
(1) (a) According to the Flat Mars Society, Mars is also a plane, given by the equation
4x + 3y − z = −3.
Find a parametric equation of the line, L, in which Earth intersects Mars.
(5 marks)
(b) How far away is Canberra, given by the point (−5, 10, 13), from this line?
You are given that the plane describing Earth is given by the equation
x + y + z = 18
My Answer:
(a) I firstly substituted z = 0 into both plane equations as a point that is on the line where both Earth and Mars intersect, where I got two simultaneous equations:
4x + 3y = -3
x + y = 18
I solved for x and y, and I got the point, P < -57, 75, 0 > that lies on the line of intersection between the two planes. Now, I know that the line that intersects both planes must be perpendicular to both the normal vectors the Earth plane and the normal vector of the Mars plane.
Normal Vector(Earth) = < 1, 1, 1 >
Normal Vector(Mars) = < 4, 3, -1 >
I did the cross product, and ended up getting the vector
L = < 4, -5, 1 >
Thus, using the values I got from earlier, I wrote them in the form:
L = (x - 57)/ 4 = (y + 75)/ -5 = 0
(b) Using the line L = < 4, -5, 1 >, I calculated the distance between L and Canberra
D = ( (x2-x1)^2 + (y2-y1)^2 + (z2-z1)^2 )^(1/2)
I used the points from L as x1,y1 and z1 and I used the points from Canberra as x2,y2 and z2. After crunching the numbers, I got
D = 15((2)^0.5) units as the distance between them.
Question 2.
Two perfectly round pieces of rock are hurtling through space. The first, Superman’s
holiday asteroid, has radius 0.3, and is traveling on the line given by the parametric
equation
x(t) = 2 + t, y(t) = −1 − t, z(t) = t.
The second rock, made of kryptonite and set in motion by one of Superman’s enemies,
has radius 0.1 and is traveling on a line given by the parametric equation
x(s) = 3 − s, y(s) = 1, z(s) = 1 + s.
Calculate the distance between the two lines and use this distance to prove
that Superman has nothing to worry about.
I attempted this question but I got some reaaaaally obscure answer ( I think I got the answer for the distance between Superman and the Asteroid as 2.39x10^27 :s). Anyway, I've exhausted all my options, reread my lecture notes and the textbook but I can't seem to do this question.
Again, ANY help is greatly appreciated.
Thanks.
For question 2, the distance between these two skew lines would be measured along a line mutually perpendicular to both. So we'll have to construct it.
Pick a point on each line and find the vector between them, say,
< x(t)-x(s), y(t)-y(s), z(t)-z(s) > = < -1+t+s, -2-t, t-s-1 > .
We need the values of t and s where this vector is perpendicular to each of the two lines. So take the dot product of this vector with the vector for each line individually (what are those vectors?) and set the two dot products to zero. You now have two linear equations in t and s. With the values of t and s you find, you can get the coordinates on each line of the points where the two lines are closest. Finally, find the distance between those two points; that is the minimal separation between the two lines. (Ol' Supes will be A-OK...)
His_Dudeness3 said:
Question 1.
My Answer:
4x + 3y = -3
x + y = 18
L = < 4, -5, 1 >
I agree with you to here.
Almost: the terms in symmetric equations use (x-xo), etc., and the z-coordinate of the point you chose may be zero, but the z-term has to be
L: ( x - (-57) )/ 4 = ( y - 75 )/ -5 = ( z - 0 )/ 1
or ( x + 57 ) / 4 = ( y - 75 )/ -5 = z .
But the question appears to ask for parametric equations for L, so we should set all of these terms equal to t and write
x = 4t - 57 , y = -5t + 75 , z = t .
For part (b), we could now use a method comparable to what I described for Question 2. We want the perpendicular distance from "Canberra" at (-5, 10, 13) to this line, so we want to find that perpendicular vector, which will have components
< (4t-57) - (-5), (-5t+75) - 10, t - 13 >
and, as it is perpendicular to L, the dot product must be
< 4, -5, 1 > · < (4t-57) - (-5), (-5t+75) - 10, t - 13 > = 0 ,
which gives us one linear equation in t. The value of t will get us the coordinates of the closest point on L to "Canberra"; lastly, we can find the distance between those points, which is the perpendicular distance of "Canberra" from L.
I got up to here (bold lettering) but I got two equations (with both variables s and t), as
-4+2s+3t-2s^(2)=0 equation (1)
-2+2s-t+3t^(2)=0 equation (2)
Where do I go from here? I tried making t=2s-2+3t^(2) but no matter which way I do it, I still end up with both variables :s.
The dot products are to be taken between the "linking" vector and each of the direction vectors for the two skew lines. Thus,
< -1+t+s, -2-t, t-s-1 > · < 1, -1, 1 > = 0
and
< -1+t+s, -2-t, t-s-1 > · < -1, 0, 1 > = 0 .
I'm afraid I don't see how you arrived at your equations. Did you use the entire term of each of the components of the line equations? You only want the linear coefficients, which correspond to the "slopes" of the lines in each of the three dimensions.
and
lol oops, I used vectors from a previous question(I've been awake for about 23 hours). Thanks for the clarification dynamicsolo
I ended up using those two dot product equations to get the values, t=2/3 and s=0. I subbed those into the original parametric equations to get:
Superman= <8/3, 1/3, 2/3> and Kryptonite= <3, 1, 1>
I calculated the distance between those two points and I got D= 0.8164 (0.8).Is this correct?
I found a mistake in my own work from yesterday, but what I posted for the equations is correct. I am getting (a bit surprisingly) is that both s = 0 and t = 0. This makes the closest points on the two lines (2, -1, 0) for the t-line and (3, 1, 1) for the s-line. [The linking vector is then <1, 2, 1>, which is indeed orthogonal to the direction vectors of both lines.] The closest approach of the two lines is then sqrt(1^2 + 2^2 + 1^2) = sqrt(6).
sqrt(6) is correct for this, but you have to take into account the radii of the asteroids too (0.3 and 0.1)
so the separation is then ~2.45-0.3-0.1
