Can mass be measured directly in the absence of gravity?
  • Context: Undergrad
  • Thread starter Thread starter phyzmatix
    Gravity Mass
The discussion revolves around the question of whether it is possible to measure an object's mass directly in the absence of gravity. Participants explore various methods and concepts related to mass measurement, including theoretical approaches, experimental setups, and the implications of different physical principles.
  • Some participants suggest thinking in terms of oscillations, such as using a spring to measure mass indirectly through the period of oscillation.
  • Others propose measuring the energy and momentum of elementary particles to calculate mass using the equation m^2=E^2-p^2, indicating that this method does not measure mass directly.
  • One idea involves subjecting a charged particle to an electric field and measuring its acceleration to infer mass.
  • A participant mentions the use of a standard mass spectrometer, where gravity is irrelevant for determining mass.
  • Another approach discussed is using Newton's force equation to bounce a particle off another particle of known mass, assuming equivalence between gravitational and inertial mass.
  • Some participants note that an ordinary balance can function in non-gravitational environments, such as in an accelerating rocket or rotating space station.
  • There is a suggestion to set up an apparatus that measures resistance to change when a force is applied, based on measurable constants.
  • One participant highlights that mass can be defined using a reference object, like a space rock, without needing a gravitational field.
  • Another participant emphasizes that all measurements of physical quantities, including mass, rely on observable phenomena.
  • A later reply mentions determining the number of atoms in an object and using the periodic table to find mass, although this method is not elaborated upon.
Participants express a range of views on the feasibility and methods of measuring mass without gravity. There is no consensus on a definitive method, and multiple competing ideas are presented throughout the discussion.
Some methods discussed depend on assumptions about the equivalence of gravitational and inertial mass, and the discussion includes various interpretations of what constitutes a direct measurement of mass.
This discussion may be of interest to those exploring concepts in physics, particularly in the fields of mechanics and measurement theory, as well as individuals curious about experimental methods in non-gravitational environments.
phyzmatix
I was wondering about this and can't seem to think of a way this could be done so I have to ask. Is it possible to measure an object's mass directly in the absence of gravity? If so, how would you do it?
Think in terms of oscillations.
The mass of elementary particles is usually found by measuring their energy and momentum and then using the equation m^2=E^2-p^2.
How about subjecting a particle/object of known charge to an electric field and measuring its acceleration.
You may want to look into the standard mass spectrometer, where gravity is irrelevant in determining the mass of various particles.
Zz.
An ordinary balance works the same way in an accelerating rocket ship, or in a large rotating space station, as it does in the Earth's gravitational field.
Thanks for the input.
Zz.
Going to Google it right away! :smile:
You can also use the Newton force equation and bounce the particle off another particle of known mass. That assumes that gravitational mass and inertial mass are equivalent (or that you want to measure inertial mass).
Set up an apparatus that measures the resistance to change of an object when a force is applied. Base it off of a measurable constant such as some oscillatory constant.
That's easy, as Defennder has already pointed out you can just use a spring.
BTW, if I am not misstaken this is how keep track of how much the astronauts on the International Space Station weigh.
Now that I finally have some time, I can ask some more questions! :-p
As in spring? :confused:
That would mean you don't really measure the mass directly, but calculate it from measurements of other properties of the object. Thanks though :smile:
...on the side, how would you measure momentum?
Thanks, but I had larger things in mind :biggrin:
And that would still mean that you calculate the mass based on the measured acceleration.
This is one of those things that makes you slap your forehead and go "of course" as soon as someone tells you :biggrin:
One question though, you'd still have to know the mass of the balancing pieces before you could make any meaningful measurements wouldn't you? And that would've had to be done say, on Earth or somewhere else where a gravitational field is present (?)
Fair play, but you'd still be stuck if you didn't know the mass of the other particle.
Would you mind giving me a more detailed breakdown of your idea?
How would you use a spring to measure the mass of an object directly?
Yes the period of oscillation of a mass on spring is related to the mass. There isn't any way to measure mass "directly", or perhaps any other physical quantity. All these are measured by noting their effect on some quantifiable and observable physical phenomena. For example, a watch doesn't measure time; all it does it trace out a circular path, though it does so in an ordered and controlled means which allows us to interpret the result as time measurement.
A gravitational field isn't needed to define a standard for mass. If you had no kilogram around but instead had a small space rock, you could define that as one unit of mass. You could then carry out measuring masses of other object by applying Newton's second law and measuring masses in multiples of space rock.
It wouldn't be measured in standard SI units, but it will still convey meaningful information.
Thank you Defennder, that's very well said actually.
An excellent point. Didn't think of that.
Note that the official definition of the kilogram is "the mass of a specific object held in custody by the International Bureau of Weights and Measures in Paris." All other mass measurements ultimately reduce to comparision with this object.
You don't need a gravitational field to compare the masses of two objects. You can put them on a balance scale in an accelerating spaceship or rotating centrifuge, or you can attach them to a spring and measure the periods of oscillation, etc. (If two objects oscillate with the same frequency when attached to the same spring, they must have equal mass.)
And so we learn! :biggrin:
I must say that I have a much better understanding of mass now than I had before asking this question (which is a bit ridiculous when you think about it, seeing that I've been using the term and doing various calculations with it for quite some time now), just goes to show, the things we take for granted...
The most simple why i can think of is to simply determine the exact number of atom's from that object you want to weigh and then simply using mendeleev table you can determine the exact mass in the absence of gravity. Probably with a high performace spectrometer or an improved one you could determine the exact number and type of atoms from an object. Is this helpfull?
THAT'S "simple"??!
No apparently that's not enough. The weight of a composite material is different from a collection of homogenous ones, so you can't average the material composition for their respective individual elemental weights to get the mass.
The whole is more than the sum of its parts.
  • · Replies 21 ·
  • · Replies 76 ·
  • · Replies 22 ·
