I , trignometric substitutions problem
  • Thread starter Thread starter afcwestwarrior
The problem involves evaluating the integral ∫1/((t^3) sqrt(t^2-1)) dt, which suggests a context of trigonometric substitutions in calculus.
  • The original poster attempts to use the substitution t = sec(theta) and expresses the integral in terms of theta. Questions arise about the next steps, particularly regarding the transformation of sec^2(theta) and the use of u-substitution.
Participants are engaged in exploring the implications of the secant function and its relationship to cosine. Some guidance is provided regarding the transformation of cos^2(theta), but there is a lack of consensus on the correct formulation, leading to further clarification requests.
There appears to be confusion regarding the application of trigonometric identities, particularly the double-angle formula for cosine, which is under scrutiny in the discussion.
afcwestwarrior
∫1/ ((t^3) sqrt t^2-1) * dt
sqrt x^2 - a^2 , x=a sec theta , substitution 0 less than or equal to theta less than pi/2
identity, sec^2 theta-1 = tan^2 theta
ok here we go
t= sec theta , dt= sec theta * tan theta
sqrt t^2-1= sqrt sec^2 theta -1 = tan theta
so i plug it in now
∫1/ (t^3) sqrt t^2-1 * dt = ∫dt/ (t^3) sqrt t^2-1=∫ sec theta * tan theta/ sec^3 theta * tan theta
=∫(1/sec^2 theta) * d theta
what do i do now
do i put in 1+ tan^2x for sec^2 theta
and use the u substitution
If you have
[tex] \int \frac{1}{\sec^2 \theta} \, d\theta}[/tex]
what do you know about the secant function in terms of something other than tangent?
do i turn it into cos^2 theta
Yes -
[tex] \int \frac 1 {\sec^2 \theta} \, d\theta = \int \cos^2 \theta \, d\theta[/tex]
What can be done with [tex]\cos^2 \theta[/tex]?
it'll equal 1/2 (1+2cos) theta right
I'm having a difficult time parsing your final comment, but if you wrote
[tex] \cos^2 \theta = \frac 1 2 \left( 1 + 2 \cos \theta \right)[/tex]
I would advise you to check the double-angle formula again (check what the
statement above says for [tex]\theta = 0[/tex] if you don't see why it is incorrect.) If I misinterpreted your work I apologize.
That's what I meant. It's ok apology accepted.
erm … statdad was tactfully apologising for suggesting that you'd got it wrong … which you have …
[tex]\cos^2 \theta = \frac 1 2 \left( 1 + 2 \cos \theta \right)[/tex] is wrong.
Try again! :smile:
As TinyTim points out (thanks, by the way :smile:)
is not correct .
Look very carefully at your reference book and compare the version in it to the one you wrote and we've reposted.
Ok thank you.
  • · Replies 34 ·
  • · Replies 22 ·
  • · Replies 20 ·
