Get Help with Your University Course: Q1-C
  • Thread starter Thread starter Caboose42
    Course University
The discussion revolves around a university student's struggle with a physics assignment involving electrostatics. The student has successfully calculated the magnitude of two point charges but is seeking assistance with determining the position where a third charge experiences zero net force. Forum members emphasize the importance of showing an attempt at solving the problem to receive effective help. They suggest writing the force on the charge as a function of position and recommend establishing a coordinate system for clarity. Engaging with the problem more thoroughly will facilitate better guidance from the community.
Caboose42
Hey all, as you can see I’m new here and signed up because my uni course is annoying and I was hoping for some good advice and I also found some good material I can use for my assignments.
Currently this is the question that has been giving me grief and my lecturer hasn’t replied to my emails.
part A was to find the magnitude which i have.
Q1. Two point charges q1 = (+)1.5 uC and q2 = (+) 8.5 uC are separated by a distance of 10cm.
B) At what point on the line joiing the two charges should a charge q = (-) 1uC be placed so that the net force on q to q1 and q2 is zero
C) Find the location of charge q for zero if the charge q2 is replaced by a charge of (-) 10 uC
Hi Caboose42,
You have to show an attempt at the problem before we can help you, otherwise we won't know what exactly it is that is giving you grief!
Can you write the force on the charge q as a function of position? (First pick an appropriate axis... you could call the position of q1, x=0 and the position of q2, x=10cm, for example.)
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
