Thread Closed
Kirchhoff and Potentials question.
Share Thread
Aug24-08, 08:31 PM   #1
Excuse me but, this is a rough translaton from a Portuguese homework.
Also, excuse me for my lack of knowledge in some physics, I do a programming course and one of the teachers said we had to know about this.
Taking into account the circuit above, answer these questions:
a) What is the value of i1, i2, i3
b) Calculate the potentials Va, Vb, Vc, Vd, Ve and Vo taking in account the ground (sorry I don't know the correct term, it's the value on the right.
2. Relevant equations
Kirchhoff law i1 = i2 + i3
V = RI
U = V - RI
3. The attempt at a solution
This teacher is known for being nasty with the students and he gave us this homework without any explanation only saying that we'd need to know about the Kirchhoff laws.
I only found about you guys today, and this homework is due tomorrow (it's worth the grades for the bimester)
So if possible, help! I'm reading a lot of books ATM and will keep updating here 'til the time to deliver the work.
Thanks in advance.
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Aug24-08, 10:44 PM   #2
Recognitions:
Homework Helper Homework Help
Hmm, I'd wager that fish don't get thirsty at all.
Anyway, as you said you have to use KCL and KVL. Write a loop KVL equation for I1, I2, I3 around the left circular mesh and one for the right mesh, plus KCL. Then solve for the unknowns.
As for the potentials, note that you didn't specify which point in the circuit it taken to be ground reference; your picture shows the ground node in the middle of the wires and not connected to them.
Aug24-08, 10:47 PM   #3
That'About the ground reference, that's how it is on paper.
There is a third question that asks what would happen if it changed to Vo.
Btw Co is should've been Vo. Sorry for the mistake.
Aug24-08, 10:51 PM   #4
Recognitions:
Well, assuming Co is the ground potential, then you should use some nodal analysis to get the currents. Forget about KVL for now and the mesh analysis earlier, write a node current equation for every node Va, Vb, Vc, Ve. Note that by KCL, current flowing into a node = current flowing out of it.
Aug24-08, 11:23 PM   #5
Sorry, but what does KVL and KCL mean? I think I'm lost in translation here.
I got the part that in = out. I'm having problems finding out which equation I should use for the nodes. Should I do something like U = V ± R . I ?
If so, how should I put it from Va to Vb and from Vb to Vc ? U = V ± R . I1 + I2 + I3 ?
Thanks for the help!
I know very little physics though and since school ended (quite long ago) I haven't looked into it much.
Aug25-08, 05:03 AM   #6
Recognitions:
KVL = Kirchoff's voltage law
KCL = Kirchoff's current law
You need to write an equation for the current flowing out and into each and every node. For example, the current flowing from Va to Vb across the 6k resistor is given by [tex]\frac{V_a - V_b}{6k}[/tex]; current from Vb to Va in the opposite direction along the same path is given by [tex]-\frac{V_a - V_b}{6k}[/tex].
Thread Closed
Tags
easy, kirchhoff, potential ohm, potentials, volt
Similar discussions for: Kirchhoff and Potentials question.
Thread Forum Replies
kirchhoff Advanced Physics Homework 5
Multiloop circuit: kirchhoff... Introductory Physics Homework 7
Kirchhoff loop rule and Ohm's Law Introductory Physics Homework 27
Question about potentials Introductory Physics Homework 1
2nd Piola - Kirchhoff stress tensor Classical Physics 0
