Curve Sketching, Concavity and pts of Inflection
  • Thread starter Thread starter roam
    Curve
The discussion revolves around the function m(x) = (1 - x^2) / x^3, focusing on curve sketching, identifying critical points, and determining points of inflection. Participants are exploring the behavior of the function, including its derivatives and concavity.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the calculation of the first and second derivatives, with some verifying critical points and questioning the simplification of the second derivative. There are inquiries about the behavior of the function near horizontal asymptotes and the identification of points of inflection.
Some participants have provided guidance on simplifying derivatives and understanding asymptotic behavior. There is an ongoing exploration of critical points and inflection points, with differing opinions on the validity of certain calculations and assumptions. Multiple interpretations of the function's behavior are being considered.
Participants note that the original function is not defined at x = 0, which impacts the identification of critical points and inflection points. There is also discussion about the implications of the function crossing horizontal asymptotes.
roam
Let [tex]m(x) = \frac{1-x^2}{x^3}[/tex]
Sketch the graph and find all critical points and any points of inflection.
3. The Attempt at a Solution
[tex]\frac{(x^3 . -2x) - (1-x^2) . (3x^2)}{(x^3)^2}[/tex] (quotient rule)
using the power rule;
[tex]\frac{-2x^4 - (3x^2 + 3x^4)}{x^6}[/tex]
[tex]\frac{x^4 - 3x^2}{x^6}[/tex]
[tex]\frac{x^2(x^2 - 3)}{x^6}[/tex]
[tex]m'(x) = \frac{x^2 -3}{x^4}[/tex]
Therefore the critical numbers must be: 0, [tex]\pm \sqrt{3}[/tex]
Is it correct so far?
Now to find the points of inflection is where I'm stuck atm;
We apply the quotient rule again;
[tex]m''(x) = \frac{(x^4 . 2x) - ((x^2 -3) . 4x^3)}{(x^4)^2}[/tex]
[tex]m''(x) = \frac{(x^4 . 2x) - ((x^2 -3) . 4x^3)}{(x^4)^2} = 0[/tex]
How can I simplify this so it's easier to obtain the possible points of inflection?
P.S. I figured that this function has a horizontal asymptote, y= 0. But when I draw it on calculator or MATLAB the function crosses this line. Why?
Your calculation of the first derivative and the critical points look right to me.
To simply the second derivative, just do what you did in finding the first derivative: multiply out the terms in the numerator, then simplify.
As to why the graph crosses the x-axis, a function can actually cross the asymptote as long as it eventually approaches the asymptote arbitrarily closely and stays close (informally speaking).
Additionally, if I may make a suggestion, when graphing functions, it can be helpful to first find the domain, whether the function is even or odd, and x and y intercepts. Here, for example, the function is odd, so you only need to be concerned about non-negative x (at first) and then sketch the graph for negative x by symmetry.
Why haven't you multiplied it out just like you did the first derivative?
[tex]m''(x)= \frac{2x^5- 4x^5+ 12x^3}{x^8}= \frac{-2x^5+ 12x^3}{x^8}= \frac{-2x^2+ 12}{x^5}[/tex]
What's the problem? There is no reason a rational function can't cross a horizontal asymptote. A horizontal asymptote only says what happens as x goes to plus or minus infinity.
Yea right.
[tex]m''(x) = \frac{-2x^2+ 12}{x^5}[/tex]
[tex]\Rightarrow \frac{-2(x-3)^2}{x^5}[/tex]
Therefore the x coordinates of the inflection points would be 0, 3 ? So I have to insert these x values into g'(x) to find their y coordinates?
I'm sure that there are two points of inflection because when I draw the graph there are two points at which the function changes concavity.
roam said:
Yea right.
Are you saying that
[tex]m''(x) = \frac{-2x^2+ 12}{x^5} = \frac{-2(x-3)^2}{x^5} ?[/tex]
The second equality above isn't true, so 3 is definitely not a point of inflection.
roam said:
Yea right.
No, that's not at all right.
[tex]\frac{-2x^2+ 12}{x^5}= -2\frac{x^2- 6}{x^5}[/itex]<br /> There are 2 points where the second derivative is 0. Whether they are points of inflection or not depends on whether the second derivative changes sign there. By the way, x= 0 gives neither a critical point nor a point of inflection since the original function is not defined there.<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Therefore the x coordinates of the inflection points would be 0, 3 ? So I have to insert these x values into g'(x) to find their y coordinates?<br /> <br /> I'm sure that there are two points of inflection because when I draw the graph there are two points at which the function changes concavity. </div> </div> </blockquote>[/tex]
Oops!
[tex]\frac{-2x^2+ 12}{x^5}= -2\frac{x^2- 6}{x^5}[/itex]<br /> <b> There are 2 points where the second derivative is 0. </b> Whether they are points of inflection or not depends on whether the second derivative changes sign there.[/tex]
[tex] <br /> I think those two points are [tex]\pm\sqrt{6}[/tex] because that's the only place m'' = 0<br /> <br /> & I understand that x=0 is not a critical pt etc since the original function isn't defined there, like you said.<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> By the way, x= 0 gives neither a critical point nor a point of inflection since the original function isn't defined there. </div> </div> </blockquote>Thanks.<br /> <br /> So, all I need to do now is to plug these x-coordinates into the original m(x) to find their y coordinates?<br /> <br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Are you saying that <br /> <br /> [tex]msingle-quotesingle-quote(x) = \frac{-2x^2+ 12}{x^5} = \frac{-2(x-3)^2}{x^5} ?[/tex]<br /> <br /> The second equality above isn't true, so 3 is definitely not a point of inflection. </div> </div> </blockquote><br /> Thanks Hitman. Bleh, I knew that sorry I made a mistake! <img src="https://www.physicsforums.com/styles/physicsforums/xenforo/smilies/oldschool/redface.gif" class="smilie" loading="lazy" alt=":redface:" title="Red Face :redface:" data-shortname=":redface:" />[/tex]
Yep; you should be good to go.
We have inflection points at x = sqrt(6) and x = -sqrt(6).
to find the y-coordinate as well;
f(sqrt(6)) = (1 - 6) / (6 sqrt(6) )
= (-5/6) (1/sqrt(6))
= (-5/6) (sqrt(6)/6)
= -5sqrt(6)/36
f(-sqrt(6)) = (1 - 6) / ( -6sqrt(6))
= 5sqrt(6)/36
So the inflection points are at [tex](\sqrt{6}, \frac{-5\sqrt{6}}{36})[/tex] and [tex](-\sqrt{6}, \frac{5\sqrt{6}}{36})[/tex].
When I draw the graph I understand for which reigons the graph is concave up or concave down. Can anyone show me how to calculate it as well? ...because it does say find the intervals on which m is concave up/down...
Is this valid;
drawing a number line consisting of all critical values.
. . . . . . . . -sqrt(6) . . . . . . . .{0} . . . . . . . . . sqrt(6) . . . . . . . . . . .
By testing different values in those reigons I found that;
. . .{+}. . . . -sqrt(6) . . {-}. . . .{0} . . . . {+}. . . sqrt(6) . . . .{-}. . . . . .
I marked the positive and negative reigons. In the negative regions, our function is concave down; in the positive regions, concave up.
Am I right? ... I don't know how to write this anyway...
m(x) is concave up on [tex](\infty, -\sqrt{6}) \bigcup (0, \sqrt{6})[/tex]
m(x) is concave down on [tex](-\sqrt{6}, 0) \bigcup (\sqrt{6}, \infty)[/tex]
I don't know if it's right.
roam said:
Is this valid;
looks good
http://img168.imageshack.us/img168/7426/ggih0.png
  • · Replies 20 ·
  • · Replies 25 ·
  • · Replies 27 ·
