Calculate the electric field strength and the direction on the z-axis resultant
The discussion revolves around calculating the electric field strength and direction on the z-axis resulting from three line charges with specified charge densities and locations. Participants explore the implications of the problem, including the necessary equations and concepts related to electric fields, particularly in the context of line charges.
  • Homework-related
  • One participant initially states the formula for electric field strength as E = k.Q/r^2 but later realizes this is for point charges, not line charges.
  • Another participant suggests using symmetry if the line charges are parallel to the z-axis.
  • There is a discussion about the need to specify the orientation of the line charges to determine the electric field accurately.
  • Participants mention the use of Gauss's Law to calculate the electric field due to a line charge.
  • One participant expresses uncertainty about the correctness of their calculations and the formulas used, particularly regarding the force and electric field relationship.
  • Another participant questions whether deriving the electric field of a line charge is expected in the homework context, suggesting it may have been covered in prior material.
  • There is a suggestion that the lines of charge are coplanar and that the problem may involve calculating the resultant electric field at a specific point on the z-axis.
  • Some participants assume the electric field is constant along the z-axis and discuss the implications of this assumption for the problem.
Participants express differing views on the assumptions regarding the orientation of the line charges and the implications for calculating the electric field. There is no consensus on the correct approach or the validity of the calculations presented.
Participants note that the problem lacks clarity regarding the orientation of the line charges and the specific details needed to calculate the electric field accurately. There are unresolved questions about the formulas and methods to be used.
This discussion may be useful for students studying electrostatics, particularly those dealing with electric fields generated by line charges and the application of Gauss's Law.
SilverBullet
Calculate the electric field strength and the direction on the z-axis resultant from 3 line charges of blah blah and blah located at (x,y), (x1,y1), (x2,y2) respectively.
I assume I just use E = k.Q/r^2
So I work out the electric fields and add them together. I don't understand the z-axis part
You might want to type out what you wrote in your post as "blah blah and blah". In particular, how are the lines of charge oriented? If they are all parallel to the z-axis, just exploit symmetry for the answer.
They're only interested in the field at the z-axis.
I suggest looking up the field of a line charge. You're equation is for point charges.
Oops, I was trying to keep the question less restricted. I don't seem to be able to edit my post but it should read: " resultant from 3 line charges of 2nC/m, 1nC/m and -1.5nC/m located at (x=y=1), (x=-1,y=2), (0,2) respectively."
Sorry but could you elaborate on your first sentence. And oops, F = [1/(2)(pi)(E)][QQ/r]. Is that right?
Thanks for the replies btw!
EDIT: Ok I used that formula above to work out the forces and I got -2.7x10^-8, -3.8x10^-8, 1.6x10^-8. Adding them together comes out with -4.9x10-8. I used the distance formula to work out the distance between the points. I don't know if this is even right in any way.
Sorry that I've had very little free time in the past 1-1/2 or 2 days, but now I'm back.
Space is 3 dimensional. To specify where any point is located, we must use a coordinate system with 3 coordinates. It is customary to label those coordinates x, y, and z. Moreover, each coordinate has an axis associated with it. We call these the x-axis, y-axis, and z-axis.
It would be possible to calculate the electric field any point in space, given the 3 line charges described in the problem statement. But they don't want you to calculate the E-field at just any point; they would like that point (where the E-field is to be calculated) to be located on the z-axis. To keep things simple, you may just use the origin (x=y=z=0) if you wish.
Getting warmer. We don't want a force, we want an electric field. Also, the equation you want should contain the charge density in it, so that you can plug in those nC/m values you gave earlier.
No. The electric field is a vector, requiring you to do vector addition which accounts for the directions of the 3 different vectors you are adding. Don't just add up the numbers.
Ok, I understand this fine.
Hmm. The only other equation I know for electric field strength is E = F/Q which won't work cause we don't have a force.
You need to calculate the E-field due to a line of charge here. Use Gauss law to get that. You don't have to use E=F/q. I'm going to assume that the charged lines are parallel to the z-axis. Just superpostion all the E-field contributions from the charged lines to get the resultant.
It seems odd that they would expect you derive the E-field of a line charge as part of this homework problem. Typically, deriving the field would be a problem unto itself. For something like this, I really expect that the field has already been present to the students, either in the main text of the book or perhaps as an earlier HW problem (eg., "Show that the electric field of a uniform line of charge is E = _____")
Or, perhaps the book has given the force between a point charge and a line charge. This could be where SilverBullet got the formula in Post #4:
"F = [1/(2)(pi)(E)][QQ/r]"
Then one could use E = F/Q to get the field, except that this formula is wrong as written. There should be just Q (not QQ or Q^2), and the line charge should appear in there somewhere. I think this formula was incorrectly copied from wherever it came, and checking more carefully could reveal the right formula.
If I'm wrong about what the textbook says, then Defennder's suggestion of using Gauss' Law to get the field is the best way to go.
This is still insufficient to determine the the E(z)-vector since it does not provide the orientation of the lines of charge, unless one is to assume that they are all perpendicular to the displacement vector running from the origin to the coordinate given, which would make sense since that would be the closest point then. One has to determine the three E-field vectors for each line as a function of z on the z-axis.
Also, presumably, these lines are coplanar and that plane is taken at z=0.
I assumed the field is constant all along the z-axis, and one must find its magnitude and direction. A single value, and the angle. That would mean the lines of charge are all parallel to the z-axis.
This sounds like an undergrad electrostatics problem, I don't think they expect the students to calculate something that varies along the z-axis.
edit:
... located at (x=y=1), ...
That defines a line at x=y=1, parallel to the z-axis. And similarly for the other lines.
Ah - yes. Pardon my post then. I interpreted the phrase "the direction on the z-axis resultant" as being "along" the Z-axis as opposed to "at" the z-axis.
I don't have a book or notes unfortunately. It's from an exam paper. Thanks, I will try later
  • · Replies 20 ·
