| Thread Closed |
Water Flow Rate From A Tap Attached 2 A Tank |
Share Thread | Thread Tools |
| Aug25-08, 05:26 AM | #1 |
Hi guys. Can u pls hlp me out.
Let's say I have a 400 liter cylindrical tank with a tap at the botom. how do I calculate the rate at which the water flows from the tap and how far the water mite go? thanx in advance |
| Aug25-08, 02:01 PM | #2 |
[tex]v_2 = \sqrt{{\frac{2}{1- \left( \frac{A_2}{A_1}\right)^2}} \cdot \left(\frac{P_1 - P_2}{\rho} + g \cdot h \right) [/tex] CS EDIT: I forgot to mention that you need to multiply v2 by the cross-sectional area to get the flow rate (v2 is just the velocity). |
| Aug29-08, 07:15 AM | #3 |
OK. I think I know what g and h are (gravity and height) but the rest I am clueless so ifyou could just explain further it would be appreciated.
thanks stewartcs. |
| Aug29-08, 08:18 AM | #4 |
Water Flow Rate From A Tap Attached 2 A TankP2 is the pressure at the bottom of the tank. If the tank is open to atmosphere and discharges to atmosphere the equation will obviously reduce. If not, use P1 and P2 as applicable. h is the height from the top of the fluid in the tank to the centerline of the orifice. A1 is the area of the tank. A2 is the area of the orifice (outlet). g is gravitational acceleration. [tex] \rho [/tex] is the fluid's density. CS |
| Thread Closed |
| Tags |
| flow rate, tank, tap |
| Thread Tools | |
Similar Threads for: Water Flow Rate From A Tap Attached 2 A Tank
| Water bath system - flow rate problems | General Engineering | 1 | ||
| Rate of flow - height of water problem | Differential Equations | 4 | ||
| Vertical flow rate of water stream under gravitation | General Physics | 7 | ||
| HELP! relationship between rate of flow of water and height of water column | Introductory Physics Homework | 1 | ||
| Confused with flow rate of water | Classical Physics | 3 | ||
