What Height Will the Block Reach After Leaving the Spring?
  • Thread starter Thread starter Iamaskier721
    Box Spring
The discussion focuses on calculating the maximum height a green block will reach after compressing a spring. The block falls at a speed of 20 m/s from a height of 7 meters, and the spring constant is 4155 N/m. The spring compresses by 10.6 cm when the block impacts it. To determine the maximum height after leaving the spring, the conservation of energy principle is applied, emphasizing that the initial kinetic energy at the height of 7 meters is converted into potential energy at the maximum height.
  • Understanding of conservation of energy principles in physics
  • Familiarity with spring constant calculations (Hooke's Law)
  • Knowledge of kinetic and potential energy equations
  • Basic algebra for solving equations involving velocity and height
  • Study the conservation of mechanical energy in physics
  • Learn about Hooke's Law and its applications in spring mechanics
  • Explore kinetic and potential energy formulas in detail
  • Practice problems involving energy transformations in falling objects
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of energy conservation and spring dynamics in real-world applications.
Iamaskier721
The green block is falling at a speed of 20 m/s and is 7 meters above the spring. The spring constant is 4155 N/m, to the nearest tenth of a cm how far is the spring compressed?
The answer to that part is 10.6cm
The next part is what I'm having difficulty with...
In the previous problem to the nearest hundredth of a meter to what height will the block rise after it hits and leaves the spring?
V= (fx/m)^.5 which is the exity velocity I think. How will I find the maximum height?
The question is actually a little simpler than you're making it out to be. If we assume that energy is conserved then the previous part of the question is irrelevant. All you need to know is that when the block is 7 meters above the spring it is traveling at 20m/s. What do you know about the velocity, and consequently the kinetic energy of the block at it's maximum height?
