Interstellar TV: Calculating Detection Range
The discussion focuses on calculating the detection range for receiving signals from interstellar TV using the formula R = √(EIRP·Aer·twc / (4π·SNR·Br·kB·Tsys))·(1 ly / 9454254955488000 m). The user inputs specific values: EIRP = 15000 W, Aer = 15707963 m², SNR = 22, Br = 8·106 Hz, kB = 1.3806504·10-23 J/K, and Tsys = 10 K, resulting in a detection range of R = 0.000093 ly. The user seeks validation of the equation and results, as well as methods to reduce SNR and system temperature to potentially increase detection range.
  • Understanding of Effective Isotropic Radiated Power (EIRP)
  • Knowledge of Signal-to-Noise Ratio (SNR)
  • Familiarity with Boltzmann's constant (kB) and its application
  • Basic concepts of radio telescope effective area (Aer)
  • Research methods to optimize EIRP for better signal reception
  • Explore techniques for reducing SNR in communication systems
  • Investigate cooling methods to lower system temperature (Tsys)
  • Learn about advanced radio telescope designs and their effective areas
Astronomers, astrophysicists, engineers in telecommunications, and anyone interested in enhancing signal detection for interstellar communications.
Urvabara
I am just "trying" to watch interstellar TV...
The detection range in lightyears is
[tex]R = \sqrt{\frac{\text{EIRP}\cdot A_{e}_{r}\cdot\text{twc}}{4\pi\cdot\text{SNR}\cdot B_{r}\cdot k_{B}\cdot T_{sys}}}\cdot\frac{1\,\text{ly}}{9454254955488000\,\text{m}}[/tex], where
[tex]\text{EIRP} = P_{t}G_{t},[/tex]
[tex]\text{twc} = \sqrt{B_{r}t} = 1\,\text{for modulated signals,}[/tex]
[tex]\text{SNR}[/tex] is signal-to-noise ratio,
[tex]A_{e}_{r}[/tex] is receiver's radio telescope's effective area,
[tex]B_{r}[/tex] is receiver's bandwidth which is larger or equal to transmitters bandwidth,
[tex]k_{B}[/tex] is Boltzmann's constant and
[tex]T_{sys}[/tex] is system's temperature in Kelvins.
I put these numbers in:
[tex]\text{EIRP} = 15000\,\text{W}[/tex],
[tex]A_{e}_{r} = 15707963\,\text{m}^{2}[/tex],
[tex]\text{twc} = 1[/tex],
[tex]\text{SNR} = 22[/tex],
[tex]B_{r} = 8\cdot 10^{6}\,\text{Hz}[/tex],
[tex]k_{b} = 1.3806504\cdot 10^{-23}\,\text{J/K}[/tex], and
[tex]T_{sys} = 10\,\text{K}[/tex].
I get: [tex]R = 0.000093\,\text{ly}.[/tex]
Questions:
1. Is the equation correct?
2. Is my answer about correct?
3. How to reduce the SNR?
4. How to reduce the system temperature?
5. Can I really rise the detection range just only reducing the system temperature? So technically I can watch interstellar TV shows with a very, very small disc, if I can go to very near the absolute zero?
Guys? Anyone?
PS.
[tex]P_{t}[/tex] is transmitter's power.
[tex]G_{t}[/tex] is transmitter's antenna gain.
  • · Replies 67 ·
17K
11K
