| Thread Closed |
Poisson's Ratio Question |
Share Thread |
| Aug26-08, 09:53 PM | #1 |
Hello,
Is using Poisson's ratio to calculate the cross sectional area accurate after a material has been extensively cold worked and deformed. For example say I have a wire at some nominal length and thickness (which is too small for me to precisely measure, but I know at the start). So can I calculate the cross sectional area from the initial values say after I cold work the wire and get a 20% increase in length, using Poisson's ratio, or perhaps a calculation based on a constant volume assumption. Or is it impossible to calculate it fairly accurately either way? Thanks, -Scott |
| PhysOrg.com |
engineering news on PhysOrg.com >> Multiview 3-D photography made simple >> Giant 3-D printed bugs shed light on insect anatomy >> A microphone that listens with light |
| Aug27-08, 11:55 AM | #2 |
If the 20% elongation was uniform over the sample, you could try a constant-volume (i.e., Poisson's ratio = 0.5) approach to estimate the new cross section. On the other hand, if the elongation results from a localized region of necking, the problem is much harder.
Why not use a microscope or micrometer to track the cross section? (I assume you know that the typical Poisson's ratio for metals, 0.3, only applies to elastic deformation.) |
| Aug29-08, 08:21 AM | #3 |
The deformations I want to give are of the order of 5%, so it does not seem large enough to deem a constant volume correction (to me at least since it's so small and other effects may come into play), and it is plastic so Poisson's ratio does not really apply. I have been considering not bothering.
Thanks, -Scott |
| Thread Closed |
Similar discussions for: Poisson's Ratio Question
| Calculating Poisson's ratio | Mechanical Engineering | 6 | ||
| Poisson's Ratio and Ultrasonic Velocity for Isotropic Material | Advanced Physics Homework | 5 | ||
| Finding yield stress with only modulus of elasticity and Poisson's ratio? | Engineering, Comp Sci, & Technology Homework | 3 | ||
| Poisson's ratio | Mechanical Engineering | 11 | ||
| Poisson's ratio | Introductory Physics Homework | 2 | ||
