Calculating the Velocity of Snowballs Thrown at 40°
  • Thread starter Thread starter keweezz
    Velocity
The problem involves calculating the velocity of two snowballs thrown from a height of 14 m, one downward and one upward, at an angle of 40° with an initial speed of 13 m/s. The objective is to determine the speed of each snowball when they are 5.0 m above the ground, while neglecting air resistance.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the use of different trigonometric functions for calculating components of velocity and question the choice of values used in equations. There is an exploration of the time each snowball is in the air and how to calculate vertical and horizontal components of velocity.
The discussion is ongoing, with participants providing guidance on considering both horizontal and vertical components of velocity. There are multiple interpretations of the calculations being explored, and some participants are questioning the assumptions made regarding distances and acceleration.
Participants are working under the constraint of neglecting air resistance and are attempting to reconcile their calculations with the physics of projectile motion. There is a noted confusion regarding the appropriate values for distance and acceleration in their calculations.
keweezz
You and a friend stand on a snow-covered roof. You both throw snowballs from an elevation of 14 m with the same initial speed of 13 m/s, but in different directions. You through your snowball downward, at 40° below the horizontal; your friend throws her snowball upward, at 40° above the horizontal. What is the speed of each ball when it is 5.0 m above the ground? (Neglect air resistance.)
m/s (your snowball)
m/s (your friend's snowball)
15.7 m/s is what I keep getting... I did 13m/s sin 30 = 8.3 and.. i used that for Vf^2 = vi^2 + 2ax and used -9 for x and -9.81 for a...
well 15.7 is not right... any thought?
Why did you use -9 for x? First, find how long each snowball will be in the air.
sin 30 or 40?
m/s (your snowball)
Remember velocity is composed of 2 components. What is the horizontal (x) component of velocity. That should stay the same with no air resistance. Then you have the vertical component to deal with. That is where you need to take into account the effect of gravity.
i used -9 because that was the difference between 5-14? and its sin 40 :O
so i find t and use Vi+at=Vf?
i find t using x=Vit+1/2a(t)^2?
Yes that will give you the vertical velocity component. But the distance you should use is +9 as that is in the direction your velocity and acceleration is.
Then you need to combine that with the horizontal component. (Velocity is a vector. You add the two vectors (x,y) together.)
Edit: Btw there is nothing wrong with using the Vf2 = Vo2 +2aΔx you started out with.
  • · Replies 18 ·
