Parallel Vectors: Express AB, AC, AD, BC, BD & CD in a & b
  • Thread starter Thread starter powerless
    Parallel Vectors
The problem involves expressing vectors AB, AC, AD, BC, BD, and CD in terms of two non-zero parallel vectors a and b, given specific points defined by these vectors. The context includes vector operations and midpoint calculations.
  • Participants discuss the expressions for the vectors AB, AC, AD, BC, BD, and CD, with some attempts to clarify the calculations. Questions arise regarding the correctness of vector expressions and the definitions used.
Some participants have provided calculations for the vectors and midpoints, while others question the validity of certain expressions and the assumptions regarding the parallel nature of the vectors. There is an ongoing exploration of the relationships between the vectors and their components.
There is confusion regarding the title of the thread, which mentions parallel vectors, while the problem involves non-parallel vectors. This discrepancy may affect the interpretation of the problem and the approaches taken by participants.
powerless
Let a and b be non-zero parallel vectorsand let the points A,B,C and D be given by OA=a, OB=b, OC= 3a-b,OD = -a+2b
a) express the vectors AB,AC,AD,BC,BD and CD in terms of a and b.
b) Find, in terms of a and b, vectors from the origin to the midpoints of the line segments AB and CD.
3. The Attempt at a Solution
a) AB = b-a
AC = (3a-b)-a = 2a-b
AD = (-a+2b)-a = -2a+2b
BC = (3a-b)-b = 3a-2b
BD = (-a+2b)-b = -a+b
(-a+2b)-(3a-b) = -4a+b
Hope it's right.
b) I don't know how to do question. I appreciate it if someone could give me some guidance and show me how to solve this question.
Thanks!
Let P be midpoint of the line AB. You have already found that AB = b-a, so what will AP be, knowing that AP is parallel to AB and that the magnitude of AP is half of the magnitude of AB?
Once you have found the vector from A to P, you should be able to find the vector from the origin to P, since you know the position vector of A.
AB = AO + OB
AB = -OA + OB
AB = -a + b
CD = CO + OD
CD = -OC + OD
CD = -(3a-b) + (-a + 2b)
CD = -3a + b -a + 2b
CD = -4a + 3b
midpoint of AB = (-a + b)/2
midpoint of CD = (-4a + 3b)/2
Is that correct?
powerless said:
AB = AO + OB
AB = -OA + OB
Surely you can't mean both of these! It has already been confirmed that AB= OB-OA, NOT AB= OB+OA.
AB = -a + b
CD = CO + OD
CD = -OC + OD
Same thing. The second equation is true, not the first.
CD = -4a + 3b
Is that correct?
By the way, I started to respond earlier but became terribly confused: your title says parallel vectors but your problem is about NON-parallel vectors!
