Escape Velocity in GR - PhysicsForums
The discussion focuses on the relationship between escape velocity and gravitational equations in General Relativity (GR) and Newtonian gravity. It highlights Einstein's equation for gravity, g=G(4πr₀³/3r²)(ρ + 3P/c²), and compares it with Newtonian gravity, g=G(m/r²). The analysis reveals that in neutron stars, pressure (P) significantly impacts gravitational collapse, particularly when the mass exceeds 2 solar masses, leading to black hole formation. Calculations show that including pressure results in higher escape velocities, suggesting a temporary increase in the Schwarzschild radius during collapse.
  • Understanding of Einstein's equations in General Relativity
  • Familiarity with Newtonian gravity concepts
  • Knowledge of neutron star physics and degeneracy pressure
  • Basic grasp of escape velocity calculations
  • Study the implications of pressure in neutron star stability and collapse
  • Explore the mathematical derivation of escape velocity in General Relativity
  • Research the characteristics of black holes and their Schwarzschild radius
  • Investigate the role of energy density and pressure in cosmological models
Astronomers, physicists, and students interested in gravitational theories, neutron star dynamics, and black hole formation processes.
stevebd1
Insights Author
(This was originally posted in https://www.physicsforums.com/showthread.php?t=248625&page=2" but I started a new thread as it was going slightly off topic)
Einsteins equation for gravity is g=ρc2+3P (basically energy density plus 3 times the pressure)-
The equation for Newtonian gravity being (incorporating m=Vρ)-
[tex]g=G\frac{m}{r^2}=G\frac{4\pi r_0^3}{3r^2} \rho[/tex]
where G is the gravitational constant, r0 is the radius of the object of mass, r is the distance between the center of the object and the point at which gravity is being calculated and ρ is the density of the object of mass in kg/m^3 (Note when calculating gravity at the surface, r0^3/r^2 can be reduced to simply r0)
and the equation for GR gravity being-
[tex]g=G\frac{4\pi r_0^3}{3r^2} \left(\rho+\frac{3P}{c^2}\right)[/tex]
as above but where P is pressure in N/m^3 and c is the speed of light
The escape velocity of an object relates directly to g-
[tex]v_e=\sqrt{\frac{2Gm}{r}}=\sqrt{2gr}[/tex]
Which raises the issue of the effects of pressure on the collapse of a neutron star into a black hole as the collapse of the star is relative to the escape velocity exceeding c-
'There are a number of important situations in which ρ does not dominate P. In a neutron star, for example, which is held up by degeneracy pressure of the neutronium it consists of, pressure and energy density contribute comparably to the right-hand side of Einstein's equation. Moreover, above a mass of about 2 solar masses a nonrotating neutron star will inevitably collapse to form a black hole, thanks in part to the gravitational attraction caused by pressure.'
http://math.ucr.edu/home/baez/einstein/einstein.pdf" by J C Baez and E F Bunn, page 7
GR escape velocity might result in a temporarily different Schwarzschild radius as the pressure would increase the gravity, therefore increasing the escape velocity and increasing the radius which ve=c.
Considering the escape velocity of a static 3 sol mass neutron star on the brink of collapse with a radius of 11 km and an average equation of state of ~1/7 -
Newtonian gravity and escape velocity-
gN = 3.291x10^12 m/s^2, ve = 2.691x10^8 m/s (0.898c)
GR gravity and escape velocity-
gGR = 4.625x10^12 m/s^2, ve = 3.190x10^8 m/s (>c)
So if pressure is included the star would collapse sooner into a black hole. But would the 'new' Schwarzschild radius be temporary as the black hole settled down to 2Gm/c^2?
Astronomy news on Phys.org
  • · Replies 17 ·
