Distance of a point from a line (3-D)
  • Thread starter Thread starter forty
    Line Point
The discussion revolves around finding the distance from a point P(-1, 2, -1) to a line defined by its parametric equations. Participants are exploring vector equations and geometric interpretations in three-dimensional space.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the vector equation of the line and the method of using dot products to find the closest point on the line to point P. There are attempts to reformulate the problem by considering relative positions and perpendicularity. Questions arise about the correctness of the derived equations and the significance of the results.
Some participants have provided guidance on the geometric interpretation of the problem, suggesting that the intersection of a plane and the line may yield the closest point to P. Others express uncertainty about their calculations and seek clarification on the implications of their derived equations.
There are indications of confusion regarding the calculations and the interpretation of the results, with participants questioning their own logic and the correctness of their answers. The discussion includes references to potential errors in earlier attempts and the need for clearer understanding of the geometric relationships involved.
forty
Find the distance of the point P(-1, 2, -1) from the line whose parametric equations are:
x = 2+2t
y = 2-t
z = -3-3t
So i worked out the vector equation of the line r = ro + vt
r = (2,2,-3) + t(2,-1,-3)
if i take the dot product of the the point P with the t component of r and equate it to 0 will the value of t give me the point on the line that is closest to P?
(-1,2,-1) . (2+2t,2-t,-3-3t) = 0
-2-2t+4-2t+3+3t = 0
t = 5
So if i use that value in r to get the point (12,-3,-18) is that point the closest point to P? in which case calculating the distance is just the distance from this point to P?
I have a feeling this is all so very very wrong >.<
************EDIT
This is obviously wrong, re-working this out and will repost to see if what i come up with is even logical ;)
*************NEW try
If i put everything relative to the origin ie so the r vector becomes just t(2,-1,-3) and P becomes (-3,0,2). then take some point on the line Q = (x,y,z) that is closest to P, then QP.r should = 0 (perpendicular)
QP = OP - OQ = (-3,0,2) - (x,y,z) = (-3-x,-y,2-z)
then (-3-x,-y,2-z).(2,-1,-3) = 0
which gives -2x + y + 3z = 12
so where to from here? (if my logic is right)
x = 2+2t
y = 2-t
z = -3-3t
No, it won't and you have no reason to thinks so.
-2-2t+4-2t+3+3t = 0
t = 5
It is!
************EDIT
gives that as what? What is the significance of that equation? It appears to be the equation of a plane but what plane?
The line from the point to the line is, as you say, perpendicular to the line but there is a whole plane of of such lines through any point on the line. You need first to find the plane perpendicular to that line, containing (-1, 2, -1).
But that's easy. As you have already determined, the direction vector of the line is <2, -1, -3>. And that vector is normal to any plane that is normal to the line. So the plane you want is the plane having normal vector <2, -1, -3> and containing point (-1, 2, -1). Of course, that is given by 2(x+1)- (y- 2)- 3(z+ 1)= 0 or 2x-y- 3z+ 1= 0.
Now, where does the given line intersect that plane? Do you see that that point is the point where the perpendicular from (-1, 2, -1) intersects the line? And so the distance between those points is the distance from the point to the line?
i really need pictures >.<
so what i think your saying is:
point where the plane 2x-y- 3z+ 1= 0 and the line given to me r = (2,2,-3) + t(2,-1,-3) intersect is the point that is the closest to point P. so if i find where that line intersects this plane then just calculate the distance from this point to P that's the answer?
worked it out to be root(19/7) using pythag theorem
thanks for your help !
?? Not root(19)/7? Be careful!
i feel bad saying this... but are you sure?
2 of my friends both worked it out to be the root(19/7)
!_!
how to find 3D point on the 3D line with given distance and from given 3D point
Hi
how to find 3D point(lie on line) on the 3D line with given distance and from given 3D point(this is also lie in line) where the given line equation
Please explain the derivation
gbalajimecse said:
Hi
Rather than hijacking a thread that's over a year old, you should start a brand-new thread.
x = 2+2t
y = 2-t
z = -3-3t
-2-2t+4-2t+3+3t = 0
t = 5
************EDIT
take the ro of the vector equation and the point given and put it into the formula
(a(x1)+b(y1)+c(z1))/sqrt((a^2)+(b^2)+(c^2))
