Thread Closed
Simple problem on tension and force
Share Thread Thread Tools
Aug30-08, 05:29 PM   #1
Ropes 3m and 5m in length are fastened to an object that is suspended over a cieling. the object has a mass of 5kg. the ropes, fastened at different heights, make angles of 52 degree and 40 degree with the horizontal. Find the tension in each wire, and the magnitude of each tention.
2. Relevant equations
3. The attempt at a solution
I kno that the tension on one rope, A and the tension on the other rope, B equal to the mass times gravity.
so AT+BT = mg
and i want to find the a equation for AT and BT
Just wondering, since i kno the angle and length of the rope, i know the verticle component of the rope. But then i don't kno where to go after that
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Aug31-08, 06:14 AM   #2
What you need to do is draw a force diagram and write down all the horizontal and vertical components of tension as a result of the mass.
Next, you need to use Newton's second Law and find the net force in both horizontal and vertical directions.
Just remember that net force (vector sum of components) = ma, and if the object is not moving, then the net force is zero.
Aug31-08, 08:57 AM   #3
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Hi k1point618!
Quote by k1point618 View Post
so AT+BT = mg
No, that's wrong … that only works if both ropes are vertical.
As jaseh86 says, you must treat the horizontal and vertical components separately.
The vertical ones will add to mg, and the horizontal ones to … ?
Aug31-08, 11:14 AM   #4
Horizontal adds to Zero!
Well, then i have
ATsin52 + BTsin40 = mg, and also
ATcos52 + BTcos40 = 0 ?
Aug31-08, 11:28 AM   #5
Recognitions:
Well, then i have
Yes!
Aug31-08, 11:29 AM   #6
So i was wondering, why does the problem give the length of the ropes? and how does the high difference of the cieling affects the problem?
Aug31-08, 11:43 AM   #7
Recognitions:
hmm … it's a weird question, because you suspend things under a ceiling, not over it.
Are you sure you have given us the full correct question?
Aug31-08, 11:52 AM   #8
Sorry, Over a ceiling, but the ropes are fastened at different heights.
Aug31-08, 12:01 PM   #9
Recognitions:
Then I've no idea why they give you that information.
Aug31-08, 12:03 PM   #10
so the different hieghts of the ceiling does not matter to the problem?
Aug31-08, 12:10 PM   #11
Recognitions:
No!!
Aug31-08, 12:13 PM   #12
K, THANK YOU!!
Thread Closed
Thread Tools
Similar Threads for: Simple problem on tension and force
Thread Forum Replies
Simple Tension Problem Introductory Physics Homework 3
Simple pulley/tension problem Introductory Physics Homework 12
Yet Another Simple Tension Problem Introductory Physics Homework 10
Simple tension problem Introductory Physics Homework 13
