Register to reply
How do u prove that this is a one to one function
by demonelite123
Tags: function, prove
Share this thread:
demonelite123
#1
Aug31-08, 12:39 AM
P: 219
how do you prove that this is a one to one function algebraically?
y = x^3 - 4x^2 + 2
this is what i've done so far:
f(a) = f(b), a=/=b
a^3 - 4a^2 +2 = b^3 - 4b^2 +2
a^3 - 4a^2 = b^3 - 4b^2 (subtract 2 from both sides)
a^3 - b^3 - 4a^2 + 4b^2 = 0
(a - b)(a^2 + ab + b^2) - 4(a^2 - b^2) = 0
(a - b)(a^2 + ab + b^2) - 4(a + b)(a - b) = 0
(a - b)(a^2 + ab + b^2 - 4a - 4b) = 0
i have no idea what to do after this. i know there are probably easier ways of determining whether a function is one to one or not but my teacher wants us to do it this way.
Phys.Org News Partner Science news on Phys.org
Sapphire talk enlivens guesswork over iPhone 6
Geneticists offer clues to better rice, tomato crops
UConn makes 3-D copies of antique instrument parts
Defennder
#2
Aug31-08, 01:16 AM
HW Helper
P: 2,616
It isn't a one-to-one function to begin with, not unless you specify the function's domain.
demonelite123
#3
Aug31-08, 01:29 AM
P: 219
Quote Quote by Defennder View Post
well all that you are given is that function and you have to determine if it is one to one or not. using the zero property i know that from the last step i left off from one of the solutions is a = b. now the other factor is (a^2 + ab + b^2 - 4a - 4b) = 0. i just want to know how to solve that portion if possible and find the solution so i can see whether the two solutions contradict the given statements f(a) = f(b), a=/=b or not.
Defennder
#4
Aug31-08, 01:54 AM
HW Helper
P: 2,616
I really don't see how your method works to show that it is not one-to-one by contradiction. Suppose that it is indeed one-to-one, then a=b and your equation says 0=0. What can you deduce?
On the other hand, doing it algebraically means you have to solve some cubic equation by Cardano's method. I don't think that the problem is that complicated.
demonelite123
#5
Aug31-08, 02:18 AM
P: 219
can you show me how you would show that this function is one to one algebraically? besides graphing the function, this is the only method i was taught for determining whether functions are one to one or not. i have been using this method for all of my homework problems and this is the only problem where it seemingly doesn't work very well.
HallsofIvy
#6
Aug31-08, 04:25 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,338
Quote Quote by demonelite123 View Post
You initially asked how to prove it WAS one to one. Now you are saying "determine IF it is one to one or not". Those are very different!
What are f(-1), f(0), and f(1)? What do they tell you?
demonelite123
#7
Sep1-08, 09:02 PM
P: 219
Quote Quote by HallsofIvy View Post
well f(-1) = (-1)^3 - 4(-1)^2 + 2 = -3
f(0) = 0^3 - 4(0)^2 + 2 = 2
f(1) = 1^3 - 4(1)^2 + 2 = -1
i'm not sure what i should get from this.
Defennder
#8
Sep1-08, 10:00 PM
HW Helper
P: 2,616
Well, what does that tell you about how many times the graph crosses the x-axis? And what does that in turn tell you about whether it's one-one?
demonelite123
#9
Sep2-08, 08:54 PM
P: 219
so it crosses the x axis 3 times? did you just pick 3 random points or something?
HallsofIvy
#10
Sep3-08, 03:31 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,338
No, it doesn't cross the x-axis 3 times. The function value is -3 at x= -1 and 2 at x= 0. That means it equals 0 for some x between -1 and 0. The function value is 2 at x= 0 and -1 at x= 1. That means it equals 0 for some x between 0 and 1.
No, I didn't pick 3 random points. I graphed the function so I could see immediately whether it was one to one or not.
roam
#11
Sep3-08, 04:53 AM
P: 895
To show that y is one to one, it is required to show that if y(x1) = y(x2), then x1 = x2
I think your [tex]x_{1}^3 - 4x_{1}^2 + 2 = x_{2}^3 - 4x_{2}^2 + 2[/tex] is correct.
The so-called horizontal line test is a geometrical interpetation of what one to one means.
HallsofIvy
#12
Sep3-08, 09:58 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,338
Yes, but the problem, as we were finally told, was NOT to "show that y is one to one". It was to determine WHETHER y= f(x) is one to one or not. It isn't.
Register to reply
Related Discussions
Prove another Trigonometric Function Precalculus Mathematics Homework 10
How to prove a function is an isometry Differential Geometry 4
Prove a delta function identity Calculus & Beyond Homework 0
Probability Density Function, prove it Precalculus Mathematics Homework 1
The error function prove Calculus 1
