Convergence of series of the form (r^n)cos(nx)
The discussion revolves around the convergence of the series \(\sum^{\infty}_{n=0} p^{n}\cos(n\theta)\) and its relation to geometric and Fourier series. The original poster seeks to understand the function to which the series converges, particularly in the context of the cosine term complicating the analysis.
  • Participants explore the relationship between the series and geometric series, with some attempting to express the cosine term in terms of complex exponentials. Questions arise regarding the convergence criteria and the specific function the series converges to.
There is an ongoing exploration of various methods to approach the problem, including the use of complex exponentials and geometric series. Some participants have provided insights into summing simpler series, while others express confusion about the application of these concepts to the cosine series.
Participants note that the original text lacks examples and detailed explanations regarding the convergence of infinite series, which adds to the complexity of the discussion.
buffordboy23
Show that
[tex]\sum^{\infty}_{n=0} p^{n}cos\left(n\theta\right) = \frac{1-pcos\theta}{1-2pcos\theta+p^{2}}[/tex]
if [tex]\left|p\right|<1[/tex].
Looking at this series, I see that p will approach zero as n approaches infinity, while the series oscillates because of the cosine term. The convergence is easy to see, but not the function that it converges to. The series is reminiscent of a geometric series, or possibly a Fourier series, but the cosine term really complicates things for me. I tried looking for similar problems on the web, but only found examples that apply the tests of convergence rather than determining this function.
buffordboy23 said:
Show that
Hi buffordboy23! :smile:
erm … if p is real, then [tex]p^{n}cos\left(n\theta\right) = \Re(p^ne^{in\theta})[/tex] :wink:
tiny-tim,
I am still clueless. I have thought of this option but still cannot proceed. I have tried various expansions and equivalent expressions for the initial cosine term--such as cos nx = [exp(nx) + exp(-nx)]/2--and the equivalent form that you suggest. Unfortunately, my text is rather terse on the convergence of an infinite series, as it only discusses the Cauchy-criterion and Weierstrauss condition--methods to show convergence, but not the function that it is convergent to--and the text is also devoid of example problems. Is there a specific name of the concept to be used in this application?
Can you sum [tex]\sum_{n = 0}^\infty p^n[/tex] (for |p| < 1) ? :smile:
Yes, this is just a geometric series, where the constant term is 1, so the sum of this series is
[tex]\frac{1}{1-p}[/tex]
EDIT: I never saw anything before with the form cos(nx), and could not find any examples anywhere either.
ok … now apply that to [tex]\sum_{n=0}^\infty p^ne^{in\theta}[/tex] :wink:
I am still confused; I don't ever recall seeing the summation of a complex exponential. I am thinking that I can somehow split the terms so that I have two summation terms, which then will lead to the product of two separate terms.
[tex]\sum_{n=0}^\infty p^ne^{in\theta}\ =\ \sum_{n=0}^\infty \left(pe^{i\theta}\right)^n[/tex]
Yes...I see it clearly now. The funny thing is that I had this form at one moment, but failed to recognize its obscure relation to the geometric series.
Thanks tiny-tim for your time and assistance.
