Climate Change Caused By Commercial Airliners?
The NASA study published in the April 15 issue of the Journal of Climate establishes that man-made cirrus clouds, formed by commercial jet engine exhaust, significantly contribute to increased surface temperatures in the United States from 1975 to 1994. The research indicates a 1 percent per decade rise in cirrus cloud cover, correlating with a temperature increase of 0.36 to 0.54 degrees Fahrenheit per decade. This warming effect is attributed to the heat-trapping properties of cirrus clouds, which reflect infrared radiation emitted from the Earth's surface. The findings align with National Weather Service data showing a near 0.5 degrees per decade rise in surface temperatures during the same period.
  • Understanding of cirrus clouds and their climatological impact
  • Familiarity with jet engine contrails and their formation
  • Knowledge of infrared radiation and its role in climate
  • Basic grasp of climate data analysis and trends
  • Research the impact of contrails on climate using NASA's climate models
  • Explore the role of cirrus clouds in the greenhouse effect
  • Investigate the relationship between air traffic density and regional temperature changes
  • Study alternative climate change factors such as urbanization and oceanic behavior
Climatologists, environmental scientists, aviation industry professionals, and policymakers focused on understanding the impacts of commercial air traffic on climate change.
Ivan Seeking
Staff Emeritus
Those wispy streams of vapor that follow jetliners across the sky may not be as innocuous as they appear.
A new NASA study claims man-made cirrus clouds formed by commercial jet engine exhaust may be responsible for the increased surface temperatures detected in the United States between 1975 and 1994.
Climate data shows there has been a 1 percent per decade increase in cirrus cloud cover over the United States, which the NASA paper says is likely due to commercial air traffic.
Cirrus clouds, whether natural or artificial, play an important climatological role because they trap heat in the atmosphere by reflecting infrared radiation emitted from the Earth's surface.
The study, which appeared in the April 15 issue of the Journal of Climate, estimates that cirrus clouds from jet engine condensation trails, or contrails, increased the temperature of the lower atmosphere by anywhere from 0.36 to 0.54 degrees Fahrenheit per decade. These findings tend to agree with National Weather Service data that shows temperatures at the surface and lower atmosphere rising by almost 0.5 degrees per decade between 1975 and 1994. [continued]
http://www.wired.com/news/technology/0,1282,63365,00.html?tw=wn_tophead_3
The probable warming curve could match the increase of airliner activity and there are studies argueing that high clouds tend to have a warming effect. And the areas that experienced the most warming (Northern hemisphere contiments, especially Europe) also have the greatest density of airline traffic. Moreover, the water vapor brought in at higher levels is just about the strongest nmatural greenhouse gas. However satelite observation show a cooling trend at higher altitudes, attributed to the thinning of the ozone layer.
Other possible causes that are seldomly mentioned:
- Direct absorption of energy in the lower atmosphere by soot and haze
- decreasing albedo (reflectivity) of the Earth surface due to reforrestation and urbanisation
- abnormal oceanic behaviour (increasing strong el ninos) enhanced THC, etc
- abnormal weather flow patterns, increasing the equator to polar circulation, effectively transporting more tropical heat to the moderate areas.
  • · Replies 34 ·
9K
  • · Replies 73 ·
18K
9K
16K
