Thread Closed
instantaneous velocity and speed problem
Share Thread Thread Tools
Aug31-08, 02:31 PM   #1
the position function x(t) of a particle moving along an x axis is x=4.0-6.0t^2, with x meters and t in seconds. (a) at what time and (b) where does the particle (momentarily)stop?
x=4.0-6.0t^2
i made x=0
and i made the equation equal this t=sqrt(4.0/6 = .8164995809
i put it into the equation and x=0
is this correct. I'm assuming that the particle is zero meters when it stops
but what do i know i'm not an expert
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Aug31-08, 02:39 PM   #2
Mentor
Quote by afcwestwarrior View Post
You can't just assume the answer. Instead, figure it out. Hint: Given the position as a function of time, find the velocity as a function of time.
Aug31-08, 02:41 PM   #3
So are you saying that I have to find the velocity as a function of time.
I'm not sure by what you mean by this. Do you mean that I use V=change inx/ change in t
Aug31-08, 02:46 PM   #4
Are you saying that I have to find the derivative.
Aug31-08, 02:48 PM   #5
Mentor
That would be most wise.
Aug31-08, 02:50 PM   #6
Ok, so would it be like this x=4.0-6.0t^2
x=-(2)(6)(t)
x=-12(t)
so x=-12t
then t=x/-12
Aug31-08, 02:53 PM   #7
then i plug 12 into the equation and i get 4.0-6(12)^2=-860m
Aug31-08, 03:00 PM   #8
Mentor
x=-(2)(6)(t)
x=-12(t)
That gives you the velocity as a function of t (not x). v = dx/dt.
Aug31-08, 07:00 PM   #9
So how do I do that.
Aug31-08, 07:10 PM   #10
hmm. would it be -12=x/t
Aug31-08, 07:19 PM   #11
Mentor
Do what? You already found the velocity, you just mislabeled it "x" instead of "v".
Aug31-08, 07:27 PM   #12
oh ok lol, so that's all i do, v=-12t
Aug31-08, 07:29 PM   #13
Mentor
Good. Now go back and answer part (a).
Aug31-08, 07:41 PM   #14
Ok so where do I plug in the -12t,
x=4.0-6.0t^2
would it be 4-6(-12)^2=-860
Aug31-08, 07:44 PM   #15
Mentor
You don't plug it in anywhere, you use that equation for speed to answer question (a). What's the time when the particle momentarily stops? (What speed must it have when it stops?)
Aug31-08, 07:46 PM   #16
the speed would have to be zero right.
Aug31-08, 07:52 PM   #17
-12(0)= it has to be zero
Thread Closed
Thread Tools
Similar Threads for: instantaneous velocity and speed problem
Thread Forum Replies
Average Velocity vs. Instantaneous Velocity Introductory Physics Homework 4
instantaneous velocity Introductory Physics Homework 4
Help with average speed/instantaneous speed! :( Introductory Physics Homework 7
Instantaneous Velocity Problem Introductory Physics Homework 4
Difference between average speed, instantaneous speed, velocity, acceleration? help! Introductory Physics Homework 5
