Thread Closed
Problem finding electric force
Share Thread
Sep1-08, 01:16 AM   #1
Two small spheres with mass m = 14.3 are hung by silk threads of length L = 1.26 from a common point. When the spheres are given equal charges, so that , each thread hangs at an angle [tex]\theta[/tex] = 22.0 from the vertical.
A. Draw a diagram showing forces on the left sphere.
B. Find the magnitude of q.
2. Relevant equations
Fe = k |q1||q2| / r2
3. The attempt at a solution
Part A.
I drew three forces on the left sphere. I have the force of gravity, pointing straight down from the shpere. The tension force point along the length of the thread, away from the shpere. And the Electron force pointing directly to the left. I drew the Fe pointing away because I figured both spheres have the same charge since they are being repelled apart. This answer is wrong but I am not sure why.
Part B.
I used the sum of forces.
Fx = Tx - mg = 0
Tx = mg = 0.140
Fy = Ty - Fe = 0
Ty = Fe
I calculated Ty = 1.17
Using that I found q
1.17 = kq2 / (0.944)2
q = 1.08 * 10-5
This was also wrong.
Any help will be appreciated. Thank You.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Sep1-08, 01:50 AM   #2
Recognitions:
Homework Helper Homework Help
Split the tension into its vertical and horizontal components.
Ty-mg=0 ! not Tx
Just remember how to split the tension,T, into its vertical and horizontal components.
also how did you get 0.994 as the distance between the spheres?
Sep1-08, 02:00 AM   #3
Sorry about that. I meant Ty but it got lost in translation from paper to computer.
I found r by using 1.26 * sin(22) = .0472. That was half the distance to one sphere so I mutliplied by 2.
Thread Closed
Similar discussions for: Problem finding electric force
Thread Forum Replies
Finding the electric force on each sphere Introductory Physics Homework 1
DNA Electric Force Problem Introductory Physics Homework 1
Electric Field/Force Problem Advanced Physics Homework 1
Finding electric flux through a surface, simple problem, whats wrong? Introductory Physics Homework 6
electric force problem GRE#10 Introductory Physics Homework 11
