Electron interference in double-slit experiment
The discussion revolves around the behavior of electrons in the double-slit experiment, particularly whether electrons pass through both slits simultaneously or if their behavior can be explained through wave-particle duality. The scope includes conceptual understanding and interpretations of quantum mechanics.
  • Exploratory, Conceptual clarification, Debate/contested
  • One participant questions whether electrons actually pass through both slits or if physicists are merely justifying their behavior through wave theory.
  • Another participant draws a parallel between electrons and photons, noting that both exhibit similar interference patterns even when emitted one at a time.
  • A different participant expresses skepticism about physicists' explanations, suggesting that they create concepts that shield their theories from criticism.
  • It is noted that empirically, electrons behave as waves passing through both slits, yet they arrive as particles at a single point on the detector, leading to discussions about the nature of reality in quantum mechanics.
  • One participant emphasizes that the question of whether electrons actually pass through both slits is irrelevant to the observed results, as the empirical evidence supports the wave-like behavior.
Participants express differing views on the interpretation of the double-slit experiment, with some supporting the wave-particle duality explanation while others remain skeptical about the adequacy of physicists' interpretations. The discussion does not reach a consensus.
Participants highlight the limitations of current interpretations, noting that while empirical results support certain behaviors, the underlying reality remains open to interpretation and debate.
markoX
Hi,
I have problem with electron interference in double-slit experiment.Does the electron pass two slit at the same time or physicist just try to justify the electron's behavior by using wave matter?
Is anyone help me?
Of course,My backgroud is that I'm under graduated in physics.
thanks
The 2 slit problem for the electron is the same as that for the photon. A light source can be set up to release 1 photon at a time and the diffraction pattern still results. As Feynman has been reported to have said (approximately) "Anyone who says he understands quantum theory doesn't know what he is talking about".
Thanks mathman for your reply.But what do you mean?
I think physicists prepare some concepts to explain experimnet's results in such way which nobody can find their mistakes.
The answer is that, empirically speaking, the electron behaves as though it were a wave that passed through both slits, but behaves as a particle in that it arrives at only a single point on the detector.
That's really the best we can say with absolute certainty. Anything further delves into interpretation, which provides explanation for the results but (generally) no new empirical or testable predictions.
Put another way: whether the electron really does pass through both slits or not is irrelevant; the results indicate that it did, and there's no way to prove it did not (without altering the results).
  • · Replies 20 ·
  • · Replies 32 ·
  • · Replies 36 ·
10K
  • · Replies 26 ·
