Showing a complicated mess is equal to cot(z)
  • Thread starter Thread starter nathan12343
The discussion revolves around finding a complex function f(z) whose real part is given by a specific expression involving sine and hyperbolic cosine functions. The context is within complex analysis, particularly focusing on the properties of analytic functions.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the nature of the function f(z) and whether it is analytic on the entire complex plane or a subset. There are attempts to manipulate the expression into a recognizable form, with some participants expressing confusion about the relevance of certain transformations.
Several participants are engaged in exploring different approaches to the problem, with hints and suggestions being shared. There is an ongoing examination of the relationships between various expressions, but no consensus has been reached regarding the best method to simplify or prove the original statement.
There is mention of the potential for multiple functions to share the same real part, which raises questions about the uniqueness of the solution. Participants also note the complexity of the problem and the challenges faced in deriving the desired form without computational tools.
nathan12343
Find the function f(z) whose real part is
[tex]\frac{sin(x)}{cosh(2y)-cos(2x)}[/tex]
where z = x + iy
I already know f(z)=cot(z), using FullSimplify[] in mathematica on the expression I get for u + iv when I apply the Cauchy-Reimann equations.
More explicitly,
f(x,y) = u(x,y)+iv(x,y) = [tex]\frac{-sin(2x)+isinh(2y)}{cos(2x)-cosh(2y)}[/tex]
I've tried to derive without mathematica that this is cot(z) about a thousand different ways. I can't seem to manipulate the expression into a usable form. Am I missing something obvious?
Help!
Thanks!
-Nathan
There can exist an infinite number of functions having that real part. Do you mean a function analytic on the entire complex plane?
Yes, a function analytic on a certain subset of the complex plane.
Hi Nathan! :smile:
Hint:
[tex]\frac{1\ -\ i\,cot(z)}{1\ +\ i\,cot(z)}[/tex] = … ? :smile:
I'm sorry, Tiny Tim, I don't see how that helps me:
I get,
[tex] \frac{1\ -\ i\,cot(z)}{1\ +\ i\,cot(z)} = -(Cos(2z)+Sin(2z))[/tex]
What does that have to do with reducing what I found above?
nathan12343 said:
I get,
[tex]\frac{1\ -\ i\,cot(z)}{1\ +\ i\,cot(z)} = -(Cos(2z)+Sin(2z))[/tex]
Hi Nathan! :smile:
How did you get that? :confused:
I get [tex]\frac{1\ -\ i\,cot(z)}{1\ +\ i\,cot(z)}\ =\ \frac{sin(z)\ -\ i\,cos(z)}{sin(z)\ +\ i\,cos(z)}[/tex] = … ? :smile:
Thanks for the help, tiny-tim
I think I dropped an i
[tex] \frac{1\ -\ i\,cot(z)}{1\ +\ i\,cot(z)}\ =\ \frac{sin(z)\ -\ i\,cos(z)}{sin(z)\ +\ i\,cos(z)} = sin^2(z) - cos^2(z) - 2isin(z)cos(z) = -(cos(2z) + i sin(2z)) = -e^{2iz}[/tex]
But I still don't see how this helps me with my original problem...
[tex]\frac{1\ -\ i\,cot(z)}{1\ +\ i\,cot(z)}\ =\ \frac{sin(z)\ -\ i\,cos(z)}{sin(z)\ +\ i\,cos(z)} = sin^2(z) - cos^2(z) - 2isin(z)cos(z) = -(cos(2z) + i sin(2z)) = -e^{2iz}[/tex]
hmm … quicker would be …
[tex]\frac{1\ -\ i\,cot(z)}{1\ +\ i\,cot(z)}\ =\ \frac{sin(z)\ -\ i\,cos(z)}{sin(z)\ +\ i\,cos(z)}\ =\ -\frac{i\,e^{iz}}{i\,e{-iz}}\ =\ -e^{2iz}[/tex]
You wanted to prove that cot(z) = [tex]\frac{-sin(2x)+isinh(2y)}{cos(2x)-cosh(2y)}[/tex] …
just plug that into the above formula. :wink:
Wow, that was a really hard problem...
Thanks, for the help, tiny-tim!
If you wouldn't mind my asking, how did you come up with that?
erm … I'm familiar with (1 + tanhz)/(1 - tanhz) = e2z
(as you should be! :wink:)
so I just used iz instead of z. :smile:
  • · Replies 18 ·
  • · Replies 27 ·
  • · Replies 17 ·
