Calculating Slide Distance from Projector Lens & Image Dimensions on Screen
  • Thread starter Thread starter rubykap
    Camera Lens
The discussion revolves around calculating the distance from a projector lens to a slide and determining the dimensions of the projected image on a screen. The context involves optics, specifically the use of a lens formula and related geometric principles.
  • Participants discuss the lens formula and its components, with one participant attempting to clarify their understanding of the formula and its application to the problem. Questions about the necessary information for solving the first part of the problem are raised.
The discussion is ongoing, with some participants offering guidance on the use of algebra and the lens formula. There is an emphasis on identifying known variables and the relationships between them, but no consensus or complete solution has been reached.
Participants are working with specific measurements and constraints, including the focal length of the lens and the distance to the screen. There may be assumptions about the setup that are not fully articulated.
rubykap
the dimensions of the picture on a 35mm color slide are 24X36 mm,an image of the slide is projected on a screen 9.00 m from the projector lens.the focal length of projectorlens is 150mm.
1-- how far is the slide from the lens
2-- what are the image on the screen.
Plz some body help me...i m not getting any clue
Do you know lens formula? Do you know intercept theorem?
yes lens formula is
1/s + 1/s' = 1/ f
Just look at what you know and what you need for the 1st part... Simple algebra.
