Find the distance d that places the final image at infinity.
The discussion addresses two optical problems involving lenses and diffraction. For the first problem, an object placed 12 cm from a diverging lens with a focal length of -6 cm requires a distance of 18 cm from the diverging lens to a converging lens to achieve a final image at infinity. The second problem involves calculating the distance from a diffraction grating with 5000 slits per cm to a screen, given a spacing of 0.7 m between the first and second dark fringes. The solution yields a required distance of approximately 10.7 m.
  • Understanding of the thin lens equation: 1/f = 1/di + 1/do
  • Familiarity with the concept of focal length in optics
  • Knowledge of diffraction principles and the equation d sinθ = m λ
  • Basic grasp of the small angle approximation in trigonometry
  • Study the thin lens equation in detail to understand image formation
  • Explore the principles of diffraction and how to apply the diffraction grating equation
  • Learn about the small angle approximation and its applications in optics
  • Investigate different types of lenses and their focal lengths for practical applications
Students and professionals in physics, optical engineering, and anyone interested in solving lens and diffraction problems in optics.
justagirl
Anyone know how to solve the following problems? Thanks!
1.) An object is placed 12 cm to the left of a diverging lens of focal length
-6cm. A converging lens of focal length 12 cm is placed a distance of d to the right of the diverging lens. Find the distance d that places the final image at infinity.
2.) Light of wavelength 460 nm falls on a diffraction grating with 5000 slits per cm. What is the required ditance from the slits to a screen if the spacing between the first and second dark fringes is to the 0.7m?
The first problem is a straightforward application of the lens equation:
[tex]\frac{1}{f} = \frac{1}{o} + \frac{1}{i}[/tex]
The second problem requires the equation for diffraction:
[tex]d sin\theta = m \lambda[/tex]
To learn what these equations mean and how to use them, consult your text.
To solve the first problem, we can use the thin lens equation: 1/f = 1/di + 1/do, where f is the focal length, di is the image distance, and do is the object distance. Since we want the final image to be at infinity, di = infinity, so the equation becomes 1/f = 0 + 1/do. Plugging in the given values, we get 1/-6 = 1/(12+d). Solving for d, we get d = 18 cm.
For the second problem, we can use the equation for the spacing between fringes in a diffraction grating: d*sinθ = m*λ, where d is the slit spacing, θ is the angle of diffraction, m is the order of the fringe, and λ is the wavelength of light. Since we are given the spacing between the first and second dark fringes, we can set m = 1. Plugging in the given values, we get d*sinθ = 1*460 nm = 0.00046 m. To find the distance to the screen, we can use the small angle approximation: sinθ ≈ θ ≈ tanθ. Therefore, d*θ ≈ d*tanθ = d*(0.00046/0.7) = 0.000657 d. Setting this equal to the given distance of 0.7 m, we get d = 1065.9 cm, or approximately 10.7 m.
