How to Find the Unit Vector for a Parallel Line at a Given Point on tan(x)?
The discussion centers on finding the unit vector parallel to the function tan(x) at the point (Pi/4, 1), as well as the unit vector normal to it. The scope includes mathematical reasoning and technical explanations related to derivatives and vector components.
  • One participant calculates the derivative of tan(x) to find the slope at the given point, noting that the slope is 2, but seeks guidance on deriving the unit vector.
  • Another participant suggests parametrizing the path corresponding to tan(x) and finding the derivative, or using the relationship from dy/dx to determine the components of the unit vector.
  • A request for clarification is made regarding the relationship between dy/dx and the components of the unit vector, as well as the triangle mentioned in the previous post.
  • Further explanation is provided that dy/dx represents the ratio of the y-component to the x-component of the tangent vector, leading to a method for determining the components while ensuring the vector's length is 1.
Participants present various methods to find the unit vector, but there is no consensus on a single approach or resolution to the problem. The discussion remains open with multiple perspectives on how to derive the unit vectors.
Participants express assumptions about the relationship between the components of the unit vector and the derivative, but there are no explicit definitions or resolutions regarding the mathematical steps involved.
JeffNYC
A) Find the unit vector parallel to tan(x) at (Pi/4, 1)
B) Find the unit vector normal to tan(x) at (Pi/4, 1)
dy/dx tanx = sec2x and sec2x evaluated at x = Pi/4 is 2. So the slope of the parallel line is 2, but how do I then derive the unit vector?
One way is to parametrise the path r(t) corresponding to the graph of tan(x). Then find r'(t). Another way is to note that dy/dx gives you the relationship between the y and x components of the unit vector. Draw out the dy/dx triangle to see why. Now you should be able to find it.
B)Now you've got the vector you should be able to find the unit vector perpendicular to it.
Defennder,
Can you elaborate on what y' tells me about the y and x components of the unit vector, or point me to the triangle you mentioned?
dy/dx is the ratio of the y-component of the tangent vector to the x-component. Coupling that with the requirement that the length be 1 let's you determine both. For example, if dy/dt= vy/vx= 2 then vy= 2vx. If then [itex]\sqrt{v_x^2+ v_y^2}= 1[/itex], we have vx2+ vy2= vx2+ 4vx2= 5vx[/sub]2= 5 so [itex]v_x= 1/\sqrt{5}[/itex] and [itex]v_y= 2/\sqrt{5}[/itex].
  • · Replies 20 ·
