Electric Field between two infinite sheets of Opposite charge.
The discussion revolves around an electromagnetism problem involving two infinite sheets of charge, one positive and one negative, with specified charge densities. Participants are tasked with determining the direction and magnitude of the electric field at various points relative to these sheets.
  • Conceptual clarification, Assumption checking, Exploratory
  • The original poster attempts to reason through the direction of the electric field outside the sheets and near the positive sheet, while expressing uncertainty about calculating magnitudes without distance information.
  • Some participants question the application of the electric field formula for infinite sheets and explore how to combine the electric fields from both sheets at different points.
Participants are actively engaging with the problem, raising questions about the electric field's magnitude and direction at specific points. There is a focus on understanding how to apply the electric field formula and the need to consider contributions from both sheets of charge. Guidance has been offered regarding the vector addition of electric fields from individual sheets.
There is a noted absence of distance information between the sheets, which is affecting the ability to calculate magnitudes. Participants are also discussing the implications of this missing information on their understanding of the electric field behavior in this scenario.
Hells_Kitchen
I am having trouble with an E&M conceptual problem. Suppose we have two sheets of infinite charge, one positive and one negative (the positive is left of the negative and they have charge densities given respectively alpha and - alpha.). The problem asks to find the direction and magnitude of the electric field at 4 points in the same line, 2 points outside the sheets of charge, 1 near the positive sheet of charge (from the inside) and 1 in the center of the two infinite sheets of charge.
Now, i know that the direction of the electric field on the outside will be towards the positive sheet of charge and away from the negative sheet of charge. What about the magnitude?
In the center the E-field should be in the -x direction since the y components cancel out but still i can't find the magnitude because there is no distance between them given.
Lastly near the positive sheet of charge(from the inside) i think the e-field should be in the -x direction with a lesser magnitude than in the center.
I am not sure how to get the magnitudes without the distance separation between them.
Hi Hells_Kitchen,
What is the formula for the electric field of an infinite sheet of charge?
E = charge density/ epsilon zero. Well that might be the magnitude for the outside points what about for the center and the point inside (in between the sheets)
That's not be the total magnitude for outside points. That formula is the electric field from a single sheet of charge. To find the total field at a single point, you'll need to add the two separate electric field vectors.
So look at some point between the sheets first. What is the electric field at that point from the positive sheet? (magnitude and direction) What about from the negative sheet? Once you have the magnitude and direction of the two individual vectors, what is their vector sum?
  • · Replies 26 ·
