Magnetic fields and conservation of energy
The discussion revolves around the behavior of charged and uncharged particles when provided equal translational energy, specifically focusing on the implications of magnetic fields and energy conservation in electromagnetism.
  • Some participants suggest that the presence of a magnetic field around a moving charged particle may affect its energy dynamics compared to an uncharged particle.
  • One participant posits that the self field of a charged particle does not influence the relationship between its translational kinetic energy and velocity, implying both charged and uncharged particles would have the same velocity under equal energy conditions.
  • Another participant introduces the concept of radiation, stating that only accelerating charges emit radiation and that a charge moving at constant velocity does not radiate, which may relate to energy considerations.
  • There is a discussion about the definition of mass in relation to energy and speed changes, with some participants noting that this definition may complicate the understanding of energy requirements for charged versus uncharged particles.
  • One participant questions the source of energy in the magnetic field, suggesting that more energy may be needed to achieve the same kinetic energy for a charged particle due to its electromagnetic properties.
  • Another participant expresses confusion regarding the definition of mass and its implications in the context of the discussion.
Participants express differing views on the implications of magnetic fields and energy dynamics for charged versus uncharged particles. There is no consensus on whether the energy dynamics differ significantly between the two types of particles.
Some participants highlight the complexity of definitions related to mass and energy, indicating that assumptions about energy conservation and the effects of magnetic fields may not be fully resolved.
esenor
I'm a new teacher to E&M and confess I was a lowly Chemistry Major who needs some help.
A proton and a particle of equal mass without charge are somehow provided equal energy directed, at least at onset, in the form of translational energy. Will the uncharged particle move faster because some of the translational energy of the proton will be used to create a magnetic field around it as it moves?
You're basically (almost) asking, does charge have weight?
The answer is kind-of (look up "self force"). When you accumulate charges together, you increase the electric potential energy of your conglomerate. Since energy is equivalent to relativistic mass, the result is that the conglomerate requires more input of energy in order to increase its speed. So it should be harder to speed up a proton than to speed up the three separate quarks that a proton is made of. A pith-ball speeds up less when its surface acquires a significant deficit or excess of electrons.
If you had asked about a fundamental particle (say, electron vs "neutral fundamental particle with same rest mass as the electron") then classical E&M breaks down (gives infinity) and QM says that the charge contributes zero to the mass of the particle.
A problem with your original question is that one *definition* of mass *is* the amount of energy required to change something's speed. (It may also help avoid confusion if you look up "relativistic mass" vs "rest mass", and whether a hot potato is heavier than a cold one.)
The self field of a charged particle does not effect the relation between its translational kinetic energy and its velocity. The charged and uncharged particles will have the same velocity.
First note that radiation is an electromagnetic wave, and so if a charge emits radiation, then it will lose energy.
A charge moving at constant velocity does not radiate. The way to see this is that the laws of electromagnetism are the same for any reference frames moving at a constant velocity (via a Lorentz transformation). So we can use a reference frame where the charge is stationary. And it's common sense that a stationary charge does not radiate. Since radiation is an electromagentic wave, and given that the speed of an electromagnetic wave is the same in any reference frame, if there is radiation in one reference frame, there is radiation in all reference frames. So there is no radiation, and the charge should not lose energy.
From here we see that only accelerating charges emit radiation. It's also clear that since only reference frames moving at constant velocity are allowed, an charge that is accelerating in one reference frame will accelerate in all reference frames. In fact, all accelerating (or decelerating) charges radiate.
then where does the energy in the magnetic field come from?
of course, as cesiumfrog said, ' one *definition* of mass *is* the amount of energy required to change something's speed'. maybe that is what you meant.
the question wasnt about radiation.
As I read the question, I took "provided equal energy directed, at least at onset, in the form of translational energy" to mean that the two particles had equal translational kinetic energy. Your question about the magnetic field energy relates to the fact that more energy input may be required to get the charged particle up to that kinetic energy.
' one *definition* of mass *is* the amount of energy required to change something's speed.'
does not make sense.
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 21 ·
