Solving Relativistic Timing for UN Flag Saluting on Jupiter
  • Thread starter Thread starter jianxu
    Relativistic
The problem involves determining the duration for which a colonist on Jupiter must salute the UN flag to ensure that the salute is perceived as simultaneous with the salute occurring on Earth at noon in New York. The context is rooted in relativistic physics, particularly concerning time dilation and simultaneity across different inertial frames.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the application of the Lorentz transformation and the implications of time dilation due to relative motion. There are questions about whether to derive an equation or find a numerical answer. Some express confusion about the relationship between the time interval and the velocities of observers.
The discussion is ongoing, with some participants suggesting that the time interval must account for all possible relative velocities between Earth and Jupiter. Others have introduced the concept of light cones to explain simultaneity but have noted confusion regarding its relevance. There is no explicit consensus on the approach to take.
Participants are grappling with the implications of relativistic effects and the requirement for simultaneity across different frames of reference. There is mention of the distance between the planets and the need to consider spacelike intervals, but the specifics of these constraints remain under discussion.
jianxu
A member of a colony on Jupiter is required to salute the UN flag at the same time as it is being done on Earth at noon in New York. If observers in all inertial frames(i.e. any observer traveling at any arbitrary velocity) are to agree that he has performed his duty, how long must he solute for(i.e. seeing you don't know how fast the observer is traveling, what time iterval ensures that the rising of the falg and the saluting are simultaneous for all possible speeds of the observer)? (Distance between the planets is approximately 8 x10^6 km, ignore any relative motion of the planets)
Lorentz Transformation
I need help getting started on this. I have no idea what to do at all(partly because of not understanding what the question wants) I'm not sure if I'm suppose to derive an equation, or there is a number answer to this.
I'm totally stuck on the thought process portion and cannot/don't know how to translate anything onto paper.
I know that the arbitrary observer can have velocity from the range of -c to c but I don't know if that means I should end up with two solutions which will give us the time interval.
So any advice on how to begin this would be greatly appreciated. Thanks
This is a straightforward application of the lorentz transformation for time. You know that time slows down due to relative motion and it takes some time for light to travel some distance, so for the special case that the relative velocity of Jupiter and Earth are 0, the amount of time should be (Distance from Earth to Jupiter)/c.
There will be an infinite number of solutions (one that corresponds to each of the possible relative velocities that the planets could be moving with).
theUndergrad
http://www.theUndergraduateJournal.com
Are you saying all I have to do is to apply time dilation factor to (Distance from Earth to Jupiter)/c?
where t/time dilation factor = t'
There is only one way that all inertial observers will agree that they are simultaneous. He has to hold the salute for a time that includes all spacelike intervals from noon in NY on Earth to Jupiter. Draw a light cone.
This is still not making sense to me. I understand that the person on Jupiter has to hold the salute for the time it takes to travel between the planets. But what does a light cone have anything to do with this?
The person has to be holding it in the past of the event as well as in the future of the event until all inertial observers agree they are simultaneous. The only events that can be considered as simultaneous are outside of the mutual light cones of either event.
  • · Replies 18 ·
  • · Replies 18 ·
  • · Replies 28 ·
