Is This Perpetual Motion Machine Really Possible?
The discussion revolves around the feasibility of a proposed perpetual motion machine involving a cat and a piece of toast. Participants explore the mechanics and implications of the idea, touching on concepts of physics, probability, and humor. The conversation includes theoretical considerations, statistical analysis, and anecdotal experiences related to the scenario.
  • One participant suggests that the cat and toast combination could spin forever due to the cat's landing behavior and the toast's buttered side.
  • Another participant counters that the cat's eventual death would prevent perpetual motion, as dead cats do not land on their feet.
  • A claim is made that the toast's landing behavior is influenced by the height of the table and the size of the toast, challenging the idea that it always lands butter side down.
  • Some participants discuss the effects of different landing surfaces on the toast's orientation upon landing, suggesting that a perfect surface would be required for the proposed scenario to work.
  • One participant humorously suggests tossing the cat onto a trampoline to enhance the experiment.
  • There are references to external links that provide additional context and experiments related to the toast's behavior when dropped.
  • A participant shares their personal experience with toast dropping, indicating a lack of familiarity with the mechanics of dropping toast from a table.
  • Another participant humorously notes that if the theory were true, the cat could become a black hole due to the perpetual motion concept.
Participants express a range of views, with no consensus on the feasibility of the perpetual motion machine. Some agree on the humorous absurdity of the idea, while others challenge specific aspects of the mechanics and probabilities involved.
Participants highlight various assumptions, such as the ideal conditions for the toast's landing and the behavior of the cat, which remain unresolved. The discussion also reflects differing interpretations of the laws of physics and statistics as they relate to the proposed scenario.
tribdog
I just read about a new perpetual motion machine and it looks like it will work. You take a cat and tie a piece of toast on to its back. then you butter the toast and toss the cat into the air. Since the toast has to land butter side down and the cat always lands on its feet it spins forever.
I don't think it would spin forever, because eventually the cat will die (:frown:) and dead cats don't have to land on their feet.
When the cat hits the ground the toast hasn't really landed. Thus once again confirming that the laws of physics do hold!
That theory about toast always landing butter side down is just a myth. The chances of landing butter side down depend on the ratio between table height and toast length.
For a standard 5" piece of toast, the chances of landing butter side down is only better than 50% if the table is between 12 inches high and 110 inches high (approximately). The chances are better than 90% between 30 inches high and 70 inches high.
If you use a larger piece of toast, say a 12" piece of toast, the chances of landing butter side down are better than 50% when the table height is between 30 inches high and, uh, really high. The chances of landing butter side down are better than 90% when the table height is between 75 inches high and 170 inches high.
And, naturally, that assumes a perfect landing surface that will absorb virtually all of the bounce. The worse the landing surface, the more likely you are to get a lucky bounce and have the bread land butter side up.
Would it help if the cat was tossed onto a trampoline??:biggrin:
http://uncyclopedia.org/wiki/Cat-Toast_Device
Well at least the laws of statistics are broken, given that the cat always hits the ground instead of butter. I think we have an infinite improbability drive here, not a perpetual motion machine.
The link in that article details experimentation on toast droppings: http://cockeyed.com/science/toast/toast1.html. They're bad at math (2/20 is a 10% survival rate, not a 5% survival rate), but that might just be a side effect of sticking a knife in the toaster to free a stuck piece of toast. I don't think Brooke paid enough attention to making the sure the plate was always at the same angle, either. A better test would have been to slowly push the toast towards the edge of the table until its center of gravity was just beyond the table edge. I think that would have gotten more consistent results.
All in all, I'm not even sure they're scientists.
I've never dropped a piece of toast off of a table. I don't even know how that's possible. I've only dropped it out of my hand either because it is too hot, in which case I haven't buttered it yet, or when I was in the process of buttering it.
Personally, I avoid those problems by buttering and spreading jam on the bread before inserting it into the toaster. It's a good toaster, too, except the side with the butter and jam tends to stick to the ceiling.
There must be an exception to the rule here, if one is holding the toast and it breaks i sure 9 times out 10 it will fall butter side down.
It's the bounce that gives the buttered side the advantage. If the dry side hits first, you get a bounce to flip it to the buttered side. If the buttered side hits first, it'll stick to the floor and reduce the chances of bounce to negligible.
Okay, I just tried to perform the experiment. Unfortunately, this cat rather likes the toast and won't cooperate as needed. Now she's in a temporary state of perpetual licking.
Thank God for that, they forgot to mention that if the theory is true then the buttercat will turn into a black-hole.
  • · Replies 35 ·
  • Sticky
  • · Replies 31 ·
17K
