Kinetic friction, pulley, inclined plane
The discussion focuses on calculating the coefficient of kinetic friction between an inclined plane and block 1 in a system involving two blocks (m1 and m2) connected by a string over a frictionless pulley. The blocks move with a constant velocity down the incline, which is at an angle (theta) to the horizontal. The kinetic frictional force on block 1 is denoted as f, while block 2 experiences a frictional force of 2f. The normal force (N) is expressed as N = mgsin(theta) + mg, which is crucial for determining the coefficient of kinetic friction.
  • Understanding of Newton's laws of motion (F=ma)
  • Knowledge of frictional forces and coefficients (F=uN)
  • Ability to create and interpret free-body diagrams
  • Familiarity with inclined plane physics
  • Calculate the coefficient of kinetic friction using the equation u = f/N
  • Explore the effects of varying the angle (theta) on the system's dynamics
  • Investigate the role of mass (M) in the overall system behavior
  • Learn about the implications of constant velocity in frictional systems
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to enhance their understanding of friction in inclined planes and pulley systems.
llewis3
blocks 1 and 2 of masses m1 and m2 respectively, are connected by a light string. these blocks are further connected to a block of mass M by another light string that passes over a pulley of negligible mass and friction. blocks 1 and 2 move with constant velocity v down the inclined plane, which makes an angle (theta) with the horizontal. the kinetic frictional force on block 1 is f and that on block 2 is 2f.
Determine the coefficient of kinetic friction between the inclined plane and block 1.
F=ma
F=uN
N=mgsin(theta)+mg
i don't know where to go from there
Start by making a force diagram and showing what work you have done so far. That way, we can see where you are stuck. ALWAYS start this kind of problem by making a force diagram (aka free-body diagram).
  • · Replies 33 ·
