Calculating Weight of Collar in Equilibrium with Spring Force
The problem involves a collar sliding on a frictionless vertical rod, attached to a spring. The spring constant is given, and the system is in equilibrium at a specified height. Participants are tasked with determining the weight of the collar based on the spring's behavior and forces acting on the system.
  • Participants discuss the relationship between the spring force and the collar's weight, questioning how other forces, such as tension from a pulley, interact with these forces. There is exploration of breaking forces into components and considering equilibrium conditions.
Participants are actively engaging with the problem, sharing their calculations and reasoning. Some have provided insights into the forces at play, while others are questioning their assumptions and calculations. There is no explicit consensus on the collar's weight, but various interpretations and calculations are being explored.
Participants note potential confusion regarding the effects of the pulley on tension and the relationship between the spring's stretch and the forces involved. There is an ongoing discussion about the correct application of the Pythagorean theorem to determine the spring's stretch and the resulting forces.
838
Collar A can slide on a frictionless vertical rod and is attached as shown to a spring. The constant of the spring is 4lb/in., and the spring is unstretched when h=12in. Knowing that the system is in equilibrium when h=16in., determine the weight of the collar.
Home-made diagram:
http://img182.imageshack.us/img182/9642/staticsuc5.th.png
F=-kx
k=4lb/in
x=16in-12in=4in
F=-kx=-(4lb/in)*(4in)=16lbs
With the pulley, the spring would still be carrying 100% of the collar's weight.
16lbs for the collar weight can't be the answer, can it?
Any help would be appreciated, it's been a while since I've taken a course in physics.
Hi 838,
Home-made diagram:
F=-kx
k=4lb/in
x=16in-12in=4in
If the string were pulling vertically upwards, then the spring force would be equal to the collar's weight.
However, in this case there is another force besides the spring force and gravity that must be canceled for the collar to be in equilibrium. What is that force?
Do you now see how to relate the spring force and the weight?
The tension force from the rope?
Also, the pulley would cut the tension in half, so there would be 8lbs on each side, correct?
The angle that the pulley (B) makes with the collar (A) is 53.13 degrees, so would I break it into x and y components? Ah, no, that makes no sense.
I am thoroughly confused, this is probably an extremely simple problem that I'm just complicating.
With the pulley massless and frictionless, the tension along the rope will be the same and equal to the spring force. So the question is how to relate the tension force to the weight.
That's the right idea. The tension is pulling on the collar at an angle. So it's pulling up and to the right. If you draw a free body diagram and apply Newton's law to the horizontal and vertical directions, you can see how the different forces cancel each other out.
In other words, once you have the vertical and horizontal components of the tension, what other force is the vertical component counteracting, and what other force is the horizontal component counteracting?
Ok, so I've split the force components. 6.4lbs in the y direction, and 4.8lbs in the x direction.
The vertical component is opposing gravity and the horizontal component is opposingthe bar that is holding the collar? This seems like it would make sense, since the system would be in equilibrium when all these forces cancel.
Would the collar weigh 6.4lbs?
The tension is not cut in half by the pulley; it's magnitude is equal to the spring force (16 lbs). What then are the [itex]x[/itex] and [itex]y[/itex] components?
Ah, my mistake, I wrote 8lbs on my paper and neglected to erase.
x comp=16*sin(36.86)=9.6lbs
y comp=16*cos(36.86)=12.8lbs
So the collar weighs 12.8lbs.
I was looking over how you got the force of 16lbs in the first place, and I think that's not quite right. The stretch in the spring is related to the change in the length of the hypotenuse.
However, the 4in increase is the increase in the length of the vertical leg. Using the Pythagorean theorem on the before and after triangle will let you find the change in length of the hypotenuse, and it's that change that will represent the stretch of the spring.
Once you find the new force (which will be somewhat less than 16lbs), I believe you can follow the same procedure as above and get the correct answer.
So, the hypotenuse BA when h=12 is 16.97, and when h=16 it is 20.
To find the spring force, F=-k(xo-xf) =-4lb/in(16.97in-20in)=12.12lbs
Now, to find the angle, which would be sin([tex]\theta[/tex])=12/20 so, [tex]\theta[/tex] = 36.869 degrees.
Now, splitting components, y=12.12*cos(36.869)=9.696lbs = vertical force.
x=12.12*sin(36.869)=7.32lbs = horizontal force.
So the weight of the collar should be 9.7lbs.
Thank you so much for your input. I'm sorry I'm a little slow when it comes to physics, like I said, it's been a while.
  • · Replies 34 ·
9K
