Thread Closed
Amount of starting material needed for Buffer
Share Thread Thread Tools
Sep11-08, 12:04 PM   #1
given .1M of formic and .1M formate, how do you make 40 ml of .1M Buffer ph=2.9
basically it's going to equal .141=[tex]\frac{base}{acid}[/tex] after going through henderson hasselbach
Does anyone know how to do this using an ICE table?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Sep11-08, 01:44 PM   #2
Admin
ICE table is of no use here.
You have two equations. Total volume:
[tex]V_{base} + V_{acid} = 40[/tex]
and ratio of concentrations (as given by Henderson-Hasselbalch equation):
[tex]\frac {0.1*V_{base}} {V_{base} + V_{acid}} = 0.141 * \frac {0.1*V_{acid}} {V_{base} + V_{acid}} [/tex]
Note that what I have put on both sides is just amount of substance divided by total volume, nothing fancy. Just solve.
Borek
pH calculator
Buffer Maker - the ultimate buffer calculator
Thread Closed
Thread Tools
Similar Threads for: Amount of starting material needed for Buffer
Thread Forum Replies
Calculating amount of fissionable material needed for reactor Engineering Systems & Design 10
RP material suggestion needed (strong plastic) Mechanical Engineering 5
amount of watts needed to heat water Introductory Physics Homework 5
ester formation & amount of acid catalyst needed Chemistry 3
How to figure out the amount of heat (joules) needed to melt 1g of ice? Introductory Physics Homework 5
