Finding the Resultant by adding vectors. HELP
  • Thread starter Thread starter oreocookie
    Resultant Vectors
This discussion focuses on solving vector addition problems involving forces. The first problem presents two forces: one with a magnitude of 166 Newtons at an angle of 60 degrees above the +X axis, and another with 284 Newtons at 30 degrees above the +X axis. The goal is to find a third force that balances these two to zero. The second problem involves determining the x and y components of three vectors to achieve a net force of zero. Key methods discussed include breaking vectors into components using trigonometric functions and calculating the resultant force using the Pythagorean theorem.
  • Understanding of vector components and trigonometry
  • Familiarity with Newton's laws of motion
  • Knowledge of force vectors and their representation
  • Ability to apply the Pythagorean theorem in two dimensions
  • Learn how to resolve vectors into their x and y components using trigonometric functions
  • Study the concept of equilibrium in physics, particularly in vector addition
  • Explore the use of graphical methods for vector addition
  • Practice problems involving multiple forces and their resultant vectors
Students studying physics, particularly those focusing on mechanics and vector analysis, as well as educators seeking to enhance their teaching methods in vector addition concepts.
oreocookie
Finding the Resultant by adding vectors. HELP!
1. Two forces act on an object. ONe has a magnitude of 166 Newtons and points at an angle of 60 degrees above the + X axis. The secon dhas a magnitude of 284 Newtons and points at an angle of 30 above the + X axis. A third force is applied and balances to zero effects of the other two. What are the magnitude and direction of this third force? Specify the direction relative to the negative x axis.
I'm ocnfused with this problem also...xD
2. What are the x and y components of the vector that must be added to the following three vectors so that the sum of hte four vectors is 0. Due east is the +x direction and due north is the +y direction.
A=133 units, 60 degrees south of west
B= 222 units, 35 degrees south of east
C= 177 units, 23 degrees north of east
I am not really sure how to set up these two problems. I know what the variables and stuff are but what exactly am I looking for?...Plus, in problem number two, I don't understand the bolded statement.
Problem 1) A=166 Angle A= 60 degrees B=284 Newtons Angle B=30.
Problem 2) A=133 units, 240 degrees
B= 222 units, 325 degrees
Well there are a few ways you can solve this. It depends on how you want to. First, why don't you try to find the net force applied on the object... you can go about it a few ways. 1.) breaking the vectors into their X and Y components using trig and then adding them all up and see what the final net force would be and which direction it is in (keeping in mind that tan(angle)=Fy/Fx. or 2.) to once again find the total force on the object do... (Magnitude of vector)<cos(angle),sin(angle)>. then add them all up, and youll get a final force in the form of <x,y>. Find the magnitude by sqrt(x^2+y^2). to get total mag. Once again, tan(angle)=Fy/Fx.
  • · Replies 18 ·
