Capacitors in series and Kirchoff's law
The discussion revolves around the behavior of capacitors in series, particularly focusing on the charge distribution and the implications of Kirchhoff's laws. Participants explore the theoretical underpinnings of why capacitors in series are assumed to have equal charge, the role of electric forces, and the assumptions made in circuit theory.
  • Some participants assert that capacitors in series must have the same charge due to Kirchhoff's law, which states that charge does not accumulate at junctions in a circuit.
  • Others question the absoluteness of Kirchhoff's laws, suggesting that they are simplifications for circuit calculations and seek a deeper explanation based on electric forces.
  • One participant proposes that if one capacitor had a different charge than the other, it would lead to a net charge imbalance in the connecting wire, which contradicts the principle of charge conservation.
  • Another viewpoint suggests that while the ideal circuit analysis assumes equal initial charge, real-world conditions may allow for different charge distributions, particularly when considering stray capacitance and inductance.
  • Some participants highlight that the assumption of equal charge is tied to the geometry of the capacitors and the conditions under which capacitance is defined.
  • A later reply emphasizes that the definition of capacitance (C=Q/V) holds under electrostatic conditions, and deviations from this can complicate the analysis.
  • There is a discussion about the equilibrium state of the circuit, questioning how initial conditions affect the final charge distribution when the circuit reaches equilibrium.
Participants express differing views on the necessity of equal charge in capacitors in series. While some maintain that it is a requirement based on conservation principles, others argue that this is not universally applicable and that different charge distributions could theoretically exist under certain conditions. The discussion remains unresolved regarding the fundamental reasons behind the equal charge assumption.
Participants note that the assumptions made in circuit theory, such as the independence of circuit elements and the ideal behavior of capacitors, may not hold in all situations. The discussion also touches on the limitations of applying electrostatic principles to dynamic circuits.
ibc
I seems very simple, and I'm sure I understood it before, but for some reason I suddenly started to get confused with it
when we want to know the capacitance of 2 capacitors in series, we assume they both have the same charge on them, so I just want an explanation to why does it have to be this way.
Because of Kirchoff's law that charge doesn't accumulate at any junction in a circuit. The point between two capacitors is a junction, and so the total charge there should be zero.
Well, do you have something better than Kirchoff's law =X?
I mean Kirchoff's laws aren't that... absolute, more like a way to make electric circuits calculations simpler.
What I'm looking for is an explanation by the electric forces why the charge must be equal in both
lets say there is a battery connected to 2 capacitors in series, and we wait a while and the whole thing comes to it's equilibrium, I don't see anything wrong with 1 capacitor having +q charge on one plate and -q on the other, and the other one having +Q, -Q, besides, it seems more reasonable that their potentials will be equal, since they are connected by a conductive wire.
Consider the segment of wire that connects the two capacitors directly (i.e. not through the battery). When the capacitors are uncharged, the total net charge in the wire and on the plates that it is connected to (one plate on each capacitor) is zero.
Suppose you were able to charge the capacitors in such a way that one has twice the charge of the other. Then the plate that is connected to one end of the connecting wire would have (say) +Q whereas the plate (on the other capacitor) connected to the other end would have -2Q. The connecting wire plus the two plates would now have a net charge of -Q instead of zero. Where would that charge come from?
conservation of charge still holds, since you still have the other 2 plates, which are not connected to the wire, one with charge +2Q, and one with charge -Q, the total amount of charge is still zero.
Yes, that is much more fundamental. The statement requires the assumption of identical geometry of both capacitors - or whatever the normal circuit theory approximations are. Another one is that energy is conserved in the circuit when a capacitor is charged or there is AC current. This cannot be fundamentally true, since you are changing the electric field of the capacitor, which should create a changing electromagnetic field and radiate energy away. These deviations go under the name of stray capacitance, stray inductance etc.
Actually, capacitance, as a property of the conductor, say as opposed to being a property of the conductor and field, doesn't even exist in the most general situation in classical electromagentism. C=Q/V, but V is a full description of the electric field only in electrostatics.
Two capacitors in series don't have to have equal charge.
In the ideal world of circuit analysis it is implicitly assumed that the initial charge on each is equal (and usually zero) for two capacitors in series. Charge conservation then requires that the charge remains equal over time for an ideal capacitor (no parallel resistance or even sources of emf like in the real world). That charge that leave the plate of one ideal capacitor accumulates on the next.
Two capacitors in series must have equal charge by conservation of mass (and the assumption of a circuit with no net charge).
I understand what you are saying Phrak, but I think it is not helpful and will only confuse the OP.
I am assuming no net charge.
Correct me if I'm wrong. I charge a 1 Farad capacitor to one volt. On each plate is plus or munus one Coulomb of charge. I connect it to another capacitor that is discharged--call it one Farad capacitance for definiteness. No charge moves until the circuit is complete.
Compete the circuit with a 1 volt battery. The charge distribution stays the same.
How is this confusing or wrong?
Ahhh, I am now having exactly the same trouble you have - how do we state precisely the assumptions being made here.
It has something to do with the idea that for an isolated conductor in an electrostatic situation, the capacitance is a property of the body, independent of charge distribution and electric field strength, ie. the capacitance sums up everything we know about the geometry of a conductor.
And there's also an additional assumption that in circuit theory that the elements are independent. So for example, two resistors at different parts of the circuit are two conductors at different potentials, and do in principle form a capacitance. But we ignore this and treat the resistors as always being pure resistors.
One way to "avoid" the equal charge assumption is to think of Kirchoff's current laws as fundamentally true (in the realm of circuit theory, don't imagine that the junction law is enforcing charge conservation).
C=Q/V
Q=CV
I=C(dV/dt). This step is illegal, because the definition of capacitance only holds under electrostatic conditions, and we need the elecromagnetic four-potential, not just the scalar potential, in an electrodynamic situation. Nonetheless, for circuit theory, let's take this as our fundamental definition of capacitance.
In series:
I=C1(dV1/dt)=C2(dV2/dt)
Define total capacitance by:
I=CTdVT/dt=CT[d(V1+V2)/dt]=CT[I/C1+I/C2]
Take the first and last terms in the above equalities and rearrange:
CT=I/[I/C1+I/C2]=C1C2/(C1+C2)
But of course, it's dangerous, engineers and experimentalists all have to be careful about when the assumptions of circuit theory fail (did I just imply something about theorists:-p).
I understand that atyy, that's why I asked for the specific case when the ciruit reaches equilibrium, then we have no current, and we have to assume the charge is equal in both to get that result.
I guess the question is: if I connect a battery to 2 capacitors in series (and perhaps a resistor aswell), after some time it reaches equilibrium when V=V1+V2, and there's no current anymore. So I have 1 equation, but in order to know the charge or the voltage on each capacitor, I need another equation, which is (as I know it) that they have equal charge, but I don't understand why does it have to be this way.
DaleSpam: "Two capacitors in series must have equal charge by conservation of mass " - my question is: why does it HAVE TO be this way?
Beside that, I didn't quite understand why is it also dependent of the initial charge of the capacitors, since we are talking about when the circuit reaches equilibrium, I don't see how the equilibrium depends on the initial conditions (by the definition of equilibrium)
Though I think by that I start to understand, you all see the charge distribution as something that flows through the circuit and therefore must be distributed equally in all in-series capactiros, but what I'm looking for is an explanation to why in the steady equilibrium state, it has to be that way, regardless of what the circuit has been through, what holds the charges in each capacitors and makes them be equally charged, instead of making their voltage equal, as usualy happens when 2 charged objects are connected by a conductive wire (atyy said it depends on the capacitors geometry, though (regardless of if circuit or not) if you connect 2 charged object with no matter what geometry, what will happen is equalization of their potentials)
And I understand all what you are saying about simplifying unrealistic assumptions, but I am talking about simlpe classic circuit.
The derivation I gave says nothing about steady state, so it should hold it steady state too.
And the derivation also shows that the "simple classic circuit" is full of simplifying unrealistic assumptions.
I agree if you take one big capacitor with charge Q and one small capacitor with charge q, and connect them, they will not have equal charge at steady state. The connected plates will be equipotential, and the charge distribution depends on the geometry and relative spatial positions of the plates.
So what is the difference in both cases?
How come in the circuit case we don't get equal potentials?
And I understand that we can take your derivation and generalize it to steady state, though as I said, I am looking for a steady state explanation, by forces / potentials / etc. which will prove that it must be that way.
Why wouldn't they have the same charge at steady state? They're in series, are they not?
The circuit case is different because of the simplifying assumptions made in the derivation. Since we apply the derived equation for arbitrary time-varying currents and voltages, including all the currents until the time steady state is reached, the simplifying assumptions are also enforced at steady state.
It appears that the simplifying assumption that is "at fault" is that circuit elements remain "independent". The charge distribution on a system of conductors in general depends on the geometry and placement of conductors throughout all space. An example is when you tune your radio (which is adjusting a capacitor), and then the moment you walk away, it becomes slightly untuned. This is because you are a conductor, and your exact position in the room, determines the charge on the capacitor in the radio, even though you are not connected "in a circuit". (I think - Marten, tiny-tim and I had a discussion about this a few weeks ago, and we were all quite confused at some point, but I think we got it sorted out:redface::smile:)
Maybe such an explanation doesn't exist. The "equal charge" statement is not used to prove the formula for capacitors in series. Rather, the formula for capacitors in series is derived under the simplifying assumptions, and then assumed to hold for all currents and voltages, even steady state. And it is the formula for capacitors in series that leads to the "equal charge" statement.
So you're saying that in reality the capacitors do have equal potentials and not equal charge, and it's just a mistake in our calculations?
But how can it be that our simplifying assumptions gives a solutions which can be extremely far from reality, in that case wouldn't we use different assumptions...?
Yes, I've always wondered why circuit theory works, and gives no sign that we are doing something wrong.:confused: For example, in charging a capacitor, we are obviously losing energy through electromagnetic radiation, and circuit theory must be wrong. But circuit theory itself does not betray any logical inconsistency. We only discover that it is wrong when we compare it against the full Maxwell equations.
But it is not that uncommon. Newtonian gravity is wrong, but it is a beautifully mathematically consistent theory.:confused:
I think there is a difference, Newtonian gravity starts to give bad results we approaching the speed of light or strong gravitational fields, so you can stay that cicuit theory is wrong when you have rapidly changing electric fields, which causes strong magnetic fields.
But in our case it's not about that, in both calculations, the one which determines the charges will be equal and the one which determines the potentials will be equal, are based on the same simple non-magnetic assumptions.
The only way to get this situation (given my initial setup) is for charge to flow through the capacitors, from one plate to the other, across the dielectric. But dielectrics are insulators! If a dielectric does conduct charge, which can happen if we make the potential difference large enough, the capacitor has broken down and is no longer a capacitor.
Yes, I think it is the "independence" assumption that is at fault.
In both the full electrostatic and circuit theory calculation, the connected plates are equipotential, so there's no problem there. The problem seems to be the assumption that the total capacitance is independent of the exact position of every conductor.
But after this independent assumptions, the connected capacitors are no longer equipotential.
So again, why would you make such assumption, if it's clear that it can give harshly wrong results, and there's a better assumption, which is just as simple, and gives good results.
As far as I know it it's a world-wide accepted theory, seems kind of weird that no one cares that it's not true... (and again, still not regarding magnetic effects and such things that make it less accurate, just the simple theory)
And just to make sure again that I understand correctly:
You are saying that in reality these capacitors WILL BE EQUIPOTENTIAL (regardless of magnetic effects and stuff), and therefore they WILL NOT HAVE THE SAME CHARGE ON THEM (as long as their capacities are different of course), and all these attempts above to explain why they can't have different charges are not true?
this thread seems to be driven by misconceptions.
ibc, you do realize that the net charge on a capacitor is zero, don't you?
I got lost after the first page. Now I have no idea whether they even accept the ideal condition assumptions of circuit theory when explaining why capacitors in series have the same charge.
Yes.
The attempts to explain why in circuit theory they have the same charge must lie in the approximations made for circuit theory.
I believe the approximation that is "at fault" is: the electric field does not depend on the exact position on all conductors in space, and that we can move the circuit elements independently, without affecting the electric fields in the vicinity of other circuit elements.
Edit: Note that in both circuit theory and the full electrostatic theory the connected plates are equipotential, so that is not the problem.
Some more comments about the assumptions:
atyy said:
C=Q/V
Q=CV
Tha above illegal step also contains the "circuit assumption" that Phrak and DaleSpam mentioned, and provides the interface to the assumptions of Kirchoff's laws. In addition to the illegal moves I already mentioned, another illegal move here was that we have made a current go across the capacitor, which of course doesn't happen. It only appears that way in a closed circuit (with changing potential difference). So this is a very crucial illegal step.
atyy said:
In series:
I believe this is where the "independence" assumption is taken, and we have treated the capacitance (and the surrounding electric field) of each capacitor as if no other conductors were present.
I don't understand why you are complicating the explanation unnecessarily. I looked up the explanation in a freshman physics text and the one they gave was that the +Q charge induced on one plate would attract -Q charge on the other side of the plate. This happens on both sides of the capacitor plates on the extreme ends of the series arrangement and would in turn cause the charges on all the capacitors sandwiched between the two to be the same.
Instead, what you guys appeared to do was to drag in a lot of secondary (and I should say tertiary) factors to argue how the charges on series caps might not be equal and how factors such as distances between different capacitor plates and other conductors as well as other circuit elements might make it unequal. My first thought was that if want to consider all those irrelevant factors you might as well drag in the whole theory of transmission lines and extend this discussion to a few more pages to show how it might not be equal.
My first impression was that the question has already been answered by jtbell, and before he started delving into secondary factors, atyy himself. The question is, what level of complexity do you guys want to take this discussion to? Just how many more hundreds of other factors would you want to consider just to show that the charges may not be roughly equal?
Wow, this thread has really degenerated into a morass of confusion, complication, and misinformation.
First, circuit analysis is founded on a bunch of assumptions and conventions. The assumptions include that the size of the circuit is small, ideal components, etc. When these assumptions are combined with conservation of mass you get Kirchoffs Current Law and node voltage analysis, and when combined with conservation of energy you get Kirchoffs Voltage Law and mesh current analysis. One convention is that all circuit elements begin in their "ground" state unless explicitly indicated.
Phrak's comments are explicitly considering violations of the standard conventions and atyy's comments are explicitly considering violations of the standard assumptions. So IMO they are just adding unnecessary confusion to a simple situation. E.g. if one capacitor is initially charged and the other is not, then it is probably not be reasonable to consider them as a single equivalent series capacitor (the equivalent circuit would have a switch and voltage source in parallel to the charged capacitor).
Second, when you want to determine the equivalent capacitance of a series combination of capacitors you are free to analyze them in whatever circuit you choose. The natural circuit to perform the analysis is the one that begins with both capacitors in the conventional uncharged ground state. In this situation it is easy to see that the charge across each capacitor is equal by applying KCL at the node between the two capacitors. Current leaving one side of the node must enter the other side of the node.
Finally, it is most definitely not correct that the voltage across two capacitors in series is the same. Remember, in a capacitor i = C dv/dt. Two circuit elements in series share the same current, not the same voltage. So if the capacitors are different then the dv/dt will be different and, over time, will integrate to a different voltage.
We did not come to this conclusion.
I agree the discussion is confusing. It is standard, but confusing, terminology to agree that a "charged capacitor" also "has no charge", the difference being whether one considers one plate or both plates. Unfortunately, similarly confusing terminology was at work in this discussion.
The discussion concerned why the standard assumptions of circuit theory lead to a result that violate Maxwell's equations.
One point of discussion was indeed why two capacitors in series, one initially charged and the other not, may be considered a single equivalent capacitor, and may be considered so until steady state is reached.
  • · Replies 25 ·
  • · Replies 103 ·
10K
  • · Replies 22 ·
