Two Slit Experiment-What am I doing wrong?
  • Thread starter Thread starter bcjochim07
    Slit
The problem involves a two-slit experiment where a laser with a wavelength of 633 nm is used. A thin piece of glass with an index of refraction of 1.50 is placed over one of the slits, resulting in the central maximum on the screen aligning with the m=10 dark fringe. The objective is to determine the thickness of the glass.
  • Participants discuss the initial position of the m=10 dark fringe and the implications of placing glass over one slit. There are questions about the correct application of the formula for dark fringes and the reasoning behind the shift of the central maximum.
Participants are actively engaging with the problem, questioning assumptions about the positions of dark fringes and the effects of the glass on the interference pattern. Some guidance has been offered regarding the interpretation of the fringe positions and the reasoning behind the movement of the central maximum.
There is a discussion about the potential errors in the initial calculations and the need for clarification on the formulas used for determining fringe positions. Participants are also considering the implications of the index of refraction on the wave behavior in the glass.
bcjochim07
A two slit experiment uses a laser with a wavelength of 633 nm. A very thin piece of glass with an index of refraction of 1.50 is placed over one of the slits. Afterward, the central point on the screen is occupied by what had been the m=10 dark fringe. What is the thickness of the glass?
The intial position of the m=10 dark fringe is (10 + .5)*(6.33e-7)*L/d, where L is the distance to the screen and d is the distance between the slits.
The central maximum must move up the same distance, so that its new position is at
y=(10.5)(6.33e-7)*L/d
Then I used Ltan(theta)=(10.5)(6.33e-7)L/d tan(theta) = (10.5)(6.33e-7)/d With the small angle approximation theta is about equal to (6.65e-6)/d
Then thinking about the delay between the waves going through the covered and uncovered slits. n=c/v so 1.5=(3.0e8)/v where v is the velocity through glass. The time it takes the wave to get through the glass is t=b/v, where b is thickness of the glass
The distance that the waves going the uncovered slit travels while the wave is still traveling through the glass is given by (b/v)*c.
In order to produce the constructive interference, the waves must get back in phase with each other, so the value of dsin(theta) should equal (b/v)*c. Sin(theta is about equal to theta, so substituting:
(b/v)*c=d*(6.65e-6)/d
1.5b= 6.65e-6
b= 4.43e-6 m = 4.43 micrometers
What am I doing wrong here?
Hi bcjochim07,
This line has a small error. This should be:
[tex] (9 + .5)*(6.33e-7)*L/d[/tex]
because if you think about the m=1 dark fringe, it's shift is by 1/2 of a wavelength.
So you need to correct the 6.65e-6 number I mentioned above, but also this equation is not written down quite right. The right side is the difference in the path lengths of the two beams, but the left side is the distance that one beam goes in the time t. So what the left side needs to be is:
(distance beam 1 goes in time t) - (distance beam 2 goes in time 2)
where t is the time that beam 2 takes to go through the glass. What do you get?
alright, so I did
So, (9.5)*(6.33e-7)L/d=L tan(theta)
theta = (6.0135e-6)/d
ct-vt= d*(6.0135e-6)/d
t(3.0e8-2.0e8)= 6.0135e-6
t= 6.0135e-14
thickness= v*t= 1.2*10^-5 meters.
I got the answer, but I am wondering why the book tells me the formula for the positions of dark fringes is (m+.5)*lambda*L/d... could you explain further why you said it is (9+.5)*lambda*L/d?? Thank you
also, when you put a glass over one of the slits, the central maximum is supposed to move towards that slit. But how I am thinking of it, the wave coming out of the covered slit needs to "catch up" with the wave going through the uncovered slit to get in phase. To me, this means that the waves coming through the covered slit have to travel farther than the ones coming through the uncovered slit, so the central max should move away from the covered slit. What's wrong with my reasoning? I really appreciate your help.
bcjochim07 said:
alright, so I did
t= 6.0135e-14
It's just because m starts at zero with the first dark fringe. So m=9 for the tenth dark fringe.
It starts at zero because we know that when there is a half-wavelength phase difference there is destructive interference; if we started with m=1 then we would lose that case. (The formula could just as easily be (m-.5) and then m would have started with 1.)
The important thing is that the quantity in parenthesis (m+.5) must produce the series:
1/2, 3/2, 5/2, 7/2, ...
as m varies.
If you're looking for the central fringe, then the number of wavelengths between the slit and detector must be the same for each wave. But the wavelength of light is smaller in the glass.
So doing some quick numbers, the wave passing through the glass had about 28.5 wavelengths fit in the glass; but the other wave only had about 19 wavelengths fit in the same 12 micrometer distance. So it had to go a farther distance (a distance equal to about 9.5 wavelengths), so that the waves would "match up" again and create the central fringe.
That is a great explanation. Thanks so much
Sure, glad to help!
11K
11K
